Old 03-10-2015, 04:02 PM   #1
Glenn Briglio
Glenn Briglio's Avatar
Liked 985 Times in 314 Posts
Default BB Chevy head gasket
What manufacturer sells the thinnest head gasket for a bb chevy 396?
Old 03-10-2015, 06:32 PM   #2
Liked 1,953 Times in 439 Posts
Default Re: BB Chevy head gasket
If you can find them anywhere, GM made one around 0.028". I think the one Mr. Gasket makes is thicker. The only other choice is either dead soft copper from some place such as Hussey or SCE, or a Cometic.
Old 03-10-2015, 10:08 PM   #3
Tim H
Tim H's Avatar
Liked 485 Times in 160 Posts
Old # used to be 1131 MR G I recall. Bore was 4.37 though.
Old 03-10-2015, 11:08 PM   #4
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
Glenn
I think I still have a set of GM ( I think .015 ) Steel gaskets. I will look in the morning and get the part # off of them.
STK1217 is offline   Reply With Quote
Old 03-10-2015, 11:36 PM   #5
MAURICE BLENDHEIM
Liked 287 Times in 88 Posts
Glenn… I've been using the MR.GASKET 1131G they are .018 -.020 thick and coated. They are 4.370 Bore and economical. Hope this helps. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 03-10-2015, 11:47 PM   #6
FED 387
Liked 336 Times in 183 Posts
GM # 14015351----steel shim .022 thickness -----4.250 bore----- STEEL HEADS ONLY------seal with alum spray paint-----re-torque after first heat cycle-- or look for LS-6 OEM gaskets ---also check quench area clearance very important!!!! FED 387
Old 03-11-2015, 12:55 AM   #7
STK1217
STK1217's Avatar
What FED 387 said, the #14015351 are the gaskets I have. Sorry I thought they were for a 396.
Mario
Old 03-11-2015, 10:32 AM   #8
Jim Hanig
Liked 99 Times in 49 Posts
Mario
Do you wish to sell them ? Jim Hanig
Old 03-11-2015, 12:21 PM   #9
Glenn Briglio
Thanks to all that responded
Old 03-11-2015, 01:01 PM   #10
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
GM# 3993890 would be the one you would want,.022 thick,small bore(4.125).Or old stock Victor equiv..The problem is they are hard to find,the Mr.G, Rocket, etc are all big bore generic BB. gsa612
