Old 03-08-2015, 11:06 AM   #21
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: U/SA help request
Originally Posted by Mike Graham View Post
When the car leaves the fuel pressure drops to zero and never recovers the rest
of the run. Enough fuel that the car doesn't miss.
The idea of let's not over spend on the fuel system didn't work out. I would have never thought that a 110 gph pump would not be enough for a 225 hp stocker.
Uh-oh, do you mind if I ask if that was a new 110gph pump ? My combo uses a 1.21 carb on a 351c but my Carter pump is rated lower.
Dave Noll, EF/S ,?/SA 6526
Old 03-08-2015, 11:13 AM   #22
Mike Graham
Liked 341 Times in 67 Posts
Dave
It was new and it was Carter.
Mike Graham is offline   Reply With Quote
Old 03-08-2015, 12:13 PM   #23
Jeff Stout
Liked 708 Times in 285 Posts
Mike now your scaring me. I was hoping 13.90 would be enough in my Olds wagon. Good job.
Old 03-08-2015, 12:52 PM   #24
Mike Graham
No worries Jeff. 1.21 not legal for this combination.
Old 03-08-2015, 12:56 PM   #25
Well, get to work then...I'll book you guys in for a match race in the Fall.
Old 03-08-2015, 01:20 PM   #26
Marty Buth
Liked 232 Times in 39 Posts
Distributor roll pin worn and moving timing around on you?
Marty Buth 3657 STK
Marty Buth is offline   Reply With Quote
Old 03-09-2015, 09:04 AM   #27
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Just a thought, I have seen the insides of braided line go bad restricting flow, so a stronger pump may be making up for that.
Mike Moller
NHRA 203 Q-R-T/SA
Old 03-10-2015, 01:55 PM   #28
Jack McCarthy
Liked 511 Times in 122 Posts
Unhappy Re: U/SA help request
pretty sure summers can fill you in on that 6 tenths difference in the carbs
captain jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 03-10-2015, 02:08 PM   #29
Billy Nees
Liked 7,925 Times in 1,760 Posts
captain jack
Couldn't prove it by me! He had me covered by .8 last weekend and I doubt he'll go any slower this weekend!
Billy Nees 1188 STK, SS
