Old 04-08-2014, 01:42 PM   #31
Damn Yankee
Default Re: Jerico modified for Racepak
Originally Posted by Dallas Kelly View Post
"Damn Yankee" sorry to take so long to answer.
No, I did not do the machine work myself. Chuck Buckshorn, friend, excellent machinist and long-time racer, actually made all the pieces. During the layout process, we discovered that the fill plug boss lined up, laterally, with where we needed to be on the cluster. The case was externally milled to adjust the angular alignment to the countershaft center line. I bought a length of, I believe, 1" aluminum hex rod that was machined into a combination fill plug/sensor adapter with o-ring seals. The split ring is very straight forward since there just is not sufficient clearance to allow very much variation of dimensions. I sold both of the modified Jerico transmissions without verifying that the design would work. However, the Jericos were replaced with Libertys, also modified by Chuck and they work with the standard Racepak clutch sensor and a single magnet in the countershaft split ring.
I think once I can find someone who can make the collar for the cluster gear shaft with the magnets, we'll be cooking with gas. Thank you Dallas
Damn Yankee is offline   Reply With Quote
Old 03-01-2015, 11:38 AM   #32
Cam
Cam's Avatar
Default Re: Racepak for stick cars
Originally Posted by Todd Hoven View Post
Has anyone put this sensor in a Gforce G-101 4 speed? Is there a good way of doing it?
Lots of good feedback on the Jerico installation but I'm still wondering if anyone has put the magnetic collar on a G101 countershaft?
Cam Chowen
6067
1994 Camaro C/S
Cam is offline   Reply With Quote
Old 03-01-2015, 05:16 PM   #33
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Contact Bubba at G-Force, I am sure he could tell you if they have, or what is involved.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-01-2015, 08:30 PM   #34
Mark Madison
Liked 32 Times in 9 Posts
I'm selling my SC-1000 racepak unit. Please see my add in the racecar parts section. Thanks Mark Madison
Mark Madison is offline   Reply With Quote
