Liked 747 Times in 362 Posts
I read that the A-1 Proflight 350-Strip Super Stock is one of the strongest TH-350 trannies made. But they are $6000.
![]() So my question is, are there any of you guys who build TH350's that will live behind a long stroke engine with just over 700hp and about the same torque ? Are some of the 9 sec SS guys using a TH350 ? If you are one of these guys would you please post your info about the trans and who built it. Please include links to the builder, or contact info if available. Thanks ! ![]() Last edited by oldskool; 01-20-2015 at 01:11 AM. |
The A pro flight is a Chrysler torque flute developed by Dave Smith good for 1400 hp
Liked 320 Times in 102 Posts
The question should be what's fast and not what's strong........
You could almost get away with an AAMCO rebuilt TH-350 trans for 700HP if all you want is strong........ Bob
#4 | |
A local racer had an 11 sec sbc Nova, with a TH350. He decided to switch to a Glide. So I bought his TH350. The TH350 had worked just fine behind his sbc. But that was because it had very little low end torque. But my 455 had about 500ft lbs @ 3000-3500rpm. So, on the first 1-2 shift, it broke the int sprag race. ![]() ![]() So, I had a another stock race put in it and sold it to another sbc racer. So to say a stock rebuilt TH350 will hold up behind a race engine with 700ft lbs of torque is ridiculous. If you can do it, fine. But 99 & 9/10 % of other racers can not get by with a stock rebuilt TH350. There are several tranny guys who advertise TH350's good to 800hp or a little over. But I decided to ask some of you class racers about it. I assume that some of you guys with big block engines are making over 500ft lbs of torque and are using a TH350 to run a little quicker than with a TH400. http://www.atiracing.com/products/trans/350/ http://www.atfspeed.com/store/index....x&cPath=193_53 http://www.coanracing.com/Catalog.as...uctDetail=1585 http://www.jakesperformance.com/TH350.html On another site someone ask what tranny would hold up behind his 700hp long stroke Pontiac engine that will also have around 700ft lbs of torque. When I mentioned a TH350, several guys jumped on it saying "no way". Since I'd read on this site about you guys using TH200's and TH350's, I decided to ask about it. The common upgrade I read about online is a 36 element sprag and drum assembly. Some even advertise a spagless set-up. So I just assumed that you guys would know who builds these HD TH350 for most of the SS racers that will survive high torque race conditions. http://www.summitracing.com/parts/tci-327900/overview/ http://www.ckperformance.com/List/GM...missions/TH350 |
Liked 1,955 Times in 590 Posts
If you are bracket racing with the combo that you have listed in the previous posts you would be better off with a powerglide. The A-1 trans is referred to as a Protrans. These are typically light weight rotating assemblies for stock, Super stock and comp type racing. They are designed for max performance and not so much for max strength. Coan also makes a similar light weight turbo 350 its called the XLT. The cost is similar. I would talk to ATI,Coan or Rossler for a recommendation on the trans for your combo
Mike Pearson 2485 SS |
Liked 535 Times in 110 Posts
The 36-element upgrade for the intermediate sprag is the cure. Not a cheap upgrade, but it will prevent failure.
Jim Kaekel 3836 STK |
Liked 99 Times in 49 Posts
If its a bracket car put a 400 in and be done.
Liked 26 Times in 12 Posts
#10 | |
and I did say almost......... AND LAST BUT NOT LEAST Start your burn out in 2nd or high gear to reduce the shock loading on the intermediate sprag Bob
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 01-22-2015 at 09:26 PM. Reason: Nore info........... |
