Curiosity question. Are ceramic type lifters still being used
by Stock Eliminator guys? If so, what do they cost ? Thanks in advance, Gerry |
Liked 69 Times in 32 Posts
Yes and approx 900.00 pr set
Ron Mattson 5015 STK |
Please be aware.......We have had the bottom fall out of a couple
of sets and destroyed engines. Be careful with valve adjustment and watch valve train.
Liked 2 Times in 1 Post
Some people are still using the Smith/Schubeck style lifters but as was previously stated if one breaks the short block is toast. A lot of people are now using Trend or PPPC tool steel lifters, limited travel for hydraulic cams.. If you're using a billet cam you have to use the coated ones. The only draw back with tool steel lifters is you can't break the cam in with them. You have to use standard lifters with reduced spring pressure or Smith/ Schubeck lifters to break the cam in.
Derek Hake 4459 H/SA 69' Roadrunner Last edited by D. Hake 4459; 01-20-2015 at 01:11 AM. |
