#11 |
Liked 1,948 Times in 589 Posts
You are all over it Larry. I have been watching the build. Cant wait to see the finished product. Keep up the good work. Thanks for posting the progress.
Mike Pearson 2485 SS |
#12 |
Liked 1,893 Times in 423 Posts
Jim Kinnett was running a 12 bolt Chevy rear end in his Super Stock Hemi 'Cuda, probably 2-3 decades ago. I'm thinking they were replacing the ring and pinion at 50 passes or so. They were not getting great life out of them. They were taking advantage of the efficiency and the lower unsprung weight, but were saying that came at a cost.
Alan Roehrich 212A G/S |
#13 |
I have pulled out a couple of cracked 5.57s with one season on them, and knocked several teeth off one at either Gilliam LA or Ennis (forget which), on the starting line, last year. That low of a gear (6.0) would make me very nervous. Mine has to weigh 3235. I have had a couple of people tell me mine hits the tires too hard. Not sure what to do about it. Feels OK in the car.
Ed Wright 4156 SS/JA |
#14 |
Although Strange Engineering makes a 12-Bolt Drop Out 9" Center Section, they only recommend its use on very lightweight cars like dragsters and altered cars.
#15 |
Kenny Faulk told me once he had one in Amy's Firebird Stocker. Don't know if he still uses them.
#16 |
Outside of factory race cars, a 9" Ford housing in a GM car isn't really legal, even if the center section accepts a 12 bolt ring and pinion, and you can't run an aluminum center section in a car that didn't have it as an OE component.
#17 |
Liked 354 Times in 120 Posts
Put a 12 bolt in my car in 87 283 220 hp glide with a brake 3200 +, 6.14 high 1.40s 60s. Raced hard for 10 years, brackets, combos, div, and natl events. All with the same set of gears, thousands of runs, lucky maybe. Made sure from the start with steel caps, rear cover girdle and made sure the set up was dead on. Put the second set in ran them till 09 when semi retired. Working on a new housing for the car, will try the 6.00 ratio with rem finished and cyro but like everything else today the stuff is just not made the same. Good luck on the build, looks great and have fun. Only rear that has less drag from gear angle is a dana 60 but they are heavy [un sprung weight]. Tom
Tom Meyer 5240 SS Stock ??? Last edited by Tom Meyer; 01-10-2015 at 09:24 AM. |
#18 |
Liked 99 Times in 60 Posts
Tom,
Thanks for the note. As suggested by you and Myron I am sending the gear set to Evans Performance in Georgia. They will do Cyro and REM treatments.
Larry Woodfin 471W |
#19 |
So, all these SS cars with 9" rears are illegal? (He isn't building a Stocker.) Boy, I have one of the few legal SS cars around here. LOL
#20 |
Liked 138 Times in 51 Posts
Larry,
My differential guy set the gears up before I sent them out because he said if you choose the "shiney" REM treatment, it's difficult to get a clear pattern. Unfortunately, you don't have the option of a drop-out center section.
LOCOMOTION Racing |
