Old 12-26-2014, 11:38 PM   #1
Dana Fitzpatrick
Liked 10 Times in 6 Posts
Default Pro gear life
I have a 3300lb,9 inch tire 68 Camaro,4-speed, that I shift w/o the clutch.Runs mid to high 9's. It has a complete Strange 12-bolt,spool,pro gears, support cover.I'm looking for estimates on gear life and what to look for when I pull the cover off.As always,thank you.
Dana Fitzpatrick is offline   Reply With Quote
Old 12-27-2014, 12:14 AM   #2
Todd Hoven
Guest
Posts: n/a
Default Re: Pro gear life
What gear ratio? Big or small block? I ran 4.88's they lasted around 75 runs with the stick. When I pulled the cover, the teeth started developing cracks on the ring gear. 3400 pound car leaving around 5k. Running 10.60's
Old 12-27-2014, 01:47 AM   #3
Don Anderson
Liked 25 Times in 9 Posts
Try these guys for gears:
Dewco
(765) 962-7201
Don Anderson is offline   Reply With Quote
Old 12-27-2014, 09:46 AM   #4
Dana Fitzpatrick
Big block,4.56's.I leave between 5400 and 5900,soft-loc clutch.
Old 12-27-2014, 10:25 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
You might also talk to Tom's Differentials in ID - http://www.tomsdifferentials.com/
HIs heat treating process usually doubles 12 bolt gear life. Cracks on the ring gear teeth are not as much to be concerned about as cracks on the pinion.
Old 12-27-2014, 01:13 PM   #6
Dave Casey
Liked 804 Times in 168 Posts
I just replaced my Richmond 4.56 12 bolt pro gear, 3250 lb bbc stick, no special treating, carefully setup originally. low 10 sec stocker I got over 250 runs out of it. I like to set them up about .001 deep, keep the pinion bearing on the high side preloadwise, and usually .003-.005 lash
hope that helps
Dave Casey 1330 STK
Old 12-31-2014, 05:43 PM   #7
Don Anderson
Try Mach Development for gear coating.
520-568-3511
Old 12-31-2014, 09:34 PM   #8
Liked 11,032 Times in 2,267 Posts
I have a Richmond pro gear I have been running in the Cuda since 1991. I change oil in it every other year and it still looks great. It is the best thing I ever bought for the car.
Old 01-01-2015, 09:24 AM   #9
tj310
I use a steel cover and weld a pipe plug in a position where you can see the teeth. They usually give a warning before they fail . ---Trevor
Old 01-02-2015, 11:02 AM   #10
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
I had 2900lbs. nova 355 nash 5 speed 3.25 1st 5.57 rear had 12 bolt all MW axles, spool,steel caps, ran 6.12-6.20 1/8 60' 1.26-1.28 usually got about 35-50 runs.
My problem was that the pinion would bend and lose backlash on one side and backlash be loose when pinion was turned 180 degrees. once I figured out what was going on by accident was pushing car and could barely push then would free up then bind again. would keep a check on it by checking backlash on gears just by jacking up and feeling of it at driveshaft.
I believe it did this because 12 bolt not having support on rear of pinion like a 9'' does
I had Mc Leod soft loc and normally ran 300-400lbs base on pressure plate and no counterweight added to levers.
Mike Taylor 3601
