Old 12-25-2014, 01:31 AM   #11
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Pulling trans from DF/S 91 Olds Delta 88 Help
Unless you have something trick, the 4T60, and the 125 have a 3.33 diff ratio, and the 4T40 has a 3.27 ratio. The best sprockets were 32 drive and 38 driven for all three units. What ratio do you think you have for the 125?
Old 12-25-2014, 06:50 PM   #12
greatinspirational
Liked 30 Times in 14 Posts
I will PM you.
greatinspirational is offline   Reply With Quote
Old 12-25-2014, 07:22 PM   #13
Liked 5,151 Times in 1,966 Posts
My friend, I told you months ago I would help you with this project.
I also asked you to not put it out there "live", and I told you why.
Russ, He's all yours now, buddy..
Old 12-25-2014, 07:51 PM   #14
ss3011
ss3011's Avatar
This problem of gear ratio is why there are not more front wheel drive cars running out there. There just is not enough gear ratio in these transmissions, so as a Band-Aid they try and make up for it with short tires. So now you have a problem with consistent traction !
Old 05-01-2015, 12:58 AM   #15
ss3011
ss3011's Avatar
your mailbox is full !
