Old 12-18-2014, 08:48 PM   #1
Nick Heath
Liked 566 Times in 135 Posts
Default HP Changes Posted, AFHS Changes for 2015
http://www.nhraracer.com/default.asp
AHFS Changes:
To decrease the potential for horsepower/index adjustments when favorable atmospheric (i.e. “mineshaft”) and/or track conditions may have contributed to extraordinary performance the NHRA has developed a system to protect the racers’ horsepower/indexes. If at the conclusion of qualifying the first competitor in the bottom half of the field is -.850 seconds or more under the class index, the Q and E Data will not be used for the mid-year and year end reviews. This will only apply to qualified fields of 32 or more cars. Automatic changes due to runs of -1.20 or more under the respective index will still count at these events. At any event where the Factory Showdown is held, no runs by Showdown cars will be used in the mineshaft calculations.
In addition, the combination must NOT make two runs of 0.650 or quicker or any run 0.850 or quicker during the past two (2) review periods, for the review to continue. Once a combination receives a horsepower increase it is not eligible for a decrease for three (3) years.
Old 12-19-2014, 10:36 AM   #2
Bobby Fazio
Bobby Fazio's Avatar
Default Re: HP Changes Posted, AFHS Changes for 2015
Originally Posted by Nick Heath View Post
Hmm, if these don't go in effect until Jan 1, 2015 then my math says I should have gotten 3hp back this last review.
'65 Mustang SS/L & L/SA
Old 12-19-2014, 12:09 PM   #3
Bryan Worner
Liked 535 Times in 86 Posts
This Mineshaft rule will almost never come into play in Super Stock! Look at all of the races in "good air" last year, where has the top of the bottom half been .850 under? I saw Indy was "mineshaft" but that's about it.
My suggestion was, "if it's mineshaft for Comp, it's mineshaft for all categories!" Others had that opinion also, but I guess the powers that be thought that would be too simple.
Bryan Worner is offline   Reply With Quote
Old 12-19-2014, 01:37 PM   #4
Marty Buth
Liked 232 Times in 39 Posts
Does this mean that the Indy U.S. Nationals will be considered "mine shaft" conditions? It took more than .850 under the index to make the 128 car field.
Marty Buth 3657 STK
Marty Buth is offline   Reply With Quote
Old 12-19-2014, 02:01 PM   #5
Nitro Joe Jackson
Nitro Joe Jackson's Avatar
Liked 67 Times in 19 Posts
just glad I don't have to keep track of who is getting hp'ed anymore way to confusing.
Nitro Joe Jackson STK 3431
nitrojoe@neo.rr.com
Old 12-19-2014, 02:29 PM   #6
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Marty, I would say yes. Only the 1-.200 (excluding FSS) penalty is in effect there, the way I read it.
Bryan, I would agree. Mineshaft for Comp = mineshaft for everyone. But Comp uses -.61 under for the first car in the bottom half (11 in a 20 car field,. 17 in a 32 car field, etc). I'm not sure what number would be fair to use. -.61 would make a lot of races 'mineshaft'. -.85, like you said, only Indy might make that cut and 1-2 others. It took -.882 to MAKE the show at Indy in Stock. Not sure what a fair number would be; maybe -.75. Just some more fun stuff to debate before Pomona.
Old 12-19-2014, 03:16 PM   #7
No HP hits at Indy..means no HP hits for factory cars.
Got it ? Good
Old 12-19-2014, 03:32 PM   #8
LDFJR
I got it Mark!
LDFJR is offline   Reply With Quote
Old 12-20-2014, 03:11 AM   #9
Bryan Worner
What I meant was if the "Mineshaft" conditions are met for Comp at a race, then Stock and Super Stock should be considered mineshaft also. So if that Comp number is -.61, then regardless of what the bottom of the top half runs in Stock and SS, they are still mineshaft. But there would still have to be a minimum number for Stock and SS for when Comp is not contested. I looked at races like the 4 Wides, where there were definitely mineshaft conditions, yet the -.85 number was not hit.
Old 12-20-2014, 10:49 AM   #10
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
Byron, I know super stock is going to be tough. Hopefully they will make a change. This is a step in the right direction. The way I like at it, races like the sports nationals in Belle Rose and some nationals with class will benefit. Last year the split for stock at Belle Rose was - .817. I think some people that may have not wanted to try for class to avoid triggers may turn it up and it may raise the numbers a bit to make more races "mineshaft."
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
