Old 10-26-2014, 08:01 AM   #11
Frank Castros
Liked 2,798 Times in 983 Posts
Default Re: looses power
Originally Posted by Myron Piatek View Post
If I may.....Try breathing through a straw (small carb), then try breathing through the cardboard spool out of a paper towel roll (big carb). You can only take in so much air in so much time through a small hole. The restriction doesn't allow you (or the engine) to breathe enough volume quickly enough to satisfy the needs. (High rpm or you running.)
Thanks Myron,
I agree about lower shifts points, but I still suspect the Super Victor intake manifold is the wrong choice, and going to test a Victor which is designed for lower rpm applications.
Old 10-26-2014, 08:46 AM   #12
Myron Piatek
Liked 138 Times in 51 Posts
Just trying to help with my perspective, and hoping Mr. Mulry doesn't mind me cutting in.
The manifold change appears to be a very good idea also. I've heard of several people disappointed with the small block version of the SV as well, noting the larger plenum volume and recommended rpm range.
LOCOMOTION Racing
Old 10-26-2014, 03:04 PM   #13
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Be my guest.....
You broke it down better than I did.........
Take care,
Bob
PS:
But on the other hand, a large plenum and a small runner can fool the engine into thinking that it has a larger carb..
There are a lot of ways to fool an engine..........
Bob Mulry 7516 STK
A & M Motorsports
Old 10-26-2014, 08:02 PM   #14
Chris Hill
Liked 244 Times in 26 Posts
GT/HA '66 Plymouth Belvedere, 426 Street Wedge, 3,675 lbs.
2.77 first gear ratio, 4.89 rear gear, shifting @ 6,500 rpm, 7,500 rpm at the finish line.
1.44 60', 4.35 @ 330, 10.80 @ 122.00 mph.
Problem is it runs out of steam at the top of the first gear.
Running an Edelbrock Super Victor with a Carter AFB 585 cfm, fresh Product Engineering 9500 Fuel Pump and 4 port regulator.
What do you guys think?
Everything seems ok. 1-2 shift sooner.
Don't go to 4.56 and 2.45 low gear. It won't leave starting line at all.
Chris Hill
Old 10-26-2014, 11:10 PM   #15
HTMtrSprt
I would agree that a large runner and plenum wouldn't cause a lack of power. Sprint cup restrictor plate motors (similar to the big motor, small carb setup) actually make power using the biggest runner size they can cut into the manifold casting. More likely a fuel delivery issue if it only occurs in low gear as that is when there is the highest 'G' loading on the fuel system.
HTMtrSprt is offline   Reply With Quote
Old 10-27-2014, 12:17 PM   #16
Glenn Briglio
Glenn Briglio's Avatar
Liked 986 Times in 314 Posts
Frank , has this combo been on an engine dyno? All the guessing and possibilities are answered.
Glenn Briglio is online now   Reply With Quote
Old 10-27-2014, 07:29 PM   #17
Frank Castros
Thanks Glenn,
This is not my car, but a friends who is not a Class Racer member and cannot post here. It was my idea to post because he's is frustrated and I knew you guys could help.
I know the engine has been dyno tested, but not flogged and I'm not familiar with the data.
Because of the small carburetor I think the Super Victor intake is too much, and he's going to try the smaller Victor at the track.
The fuel delivery theory has been adequately addressed, and I agree the 2.77 low gear and 4.89 rear are correct for the combination, also shifting at 6,000 seems to make sense.
Thanks to everyone for the thoughts, but if there are more ideas, I'm all ears.
He's only looking to go 10.40s or 50s.
Old 10-27-2014, 07:58 PM   #18
69Cobra
Liked 2 Times in 2 Posts
1320/122=10.819 It sounds like he's right on target with the power he's making.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 10-27-2014, 08:59 PM   #19
Pvt Parts
Pvt Parts's Avatar
There's always more!
Old 10-27-2014, 10:01 PM   #20
69Cobra
Yes. But there's not 3 or 4 tenths more with the same hp to run 122mph.
Just curious does anybody have good data on what it takes hp wise to pick up 1 tenth at this level?
Kris Rachford
C/S 3032
