#31 |
Liked 708 Times in 285 Posts
Bought a quadrajet from carb builder x and I was told to buy from carb builder y. X was slower front half and Y was slower in back half. Same ET.
Take the rubber seal off where hood meets firewall. Found out it wasn't legal. Put seal on and it went faster. Had square lipped seal on brake calipers. Put the round type seal on and have less drag. No ET gain. I quit at 8 converters for one motor combo. Monte has more frontal area then Camaro so you need more gear. Went from 5.67 to 5.86 nothing gained but a couple more RPM's at finish line. |
#32 |
Liked 202 Times in 52 Posts
Snake oil, fancy plugs and wires and yes those damn converter things
![]() ![]() Kevin |
#33 |
Liked 405 Times in 158 Posts
#34 |
Liked 279 Times in 68 Posts
I've learned just as much from what doesn't work as from what does work. If you don't try things you don't advance.
Greg Hill 4171 STK |
#35 |
Liked 2 Times in 2 Posts
That's the best post in this thread!
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#36 |
Exactly!
Ed Wright 4156 SS/JA |
#37 |
Recommendation from a highly respected manufacturer, for an uncontrollable "square" intake cam lobe. Then further recommendation for "glass-like" tool steel retainers. Then further recommendation for beehive springs with smaller "glass-like" tool steel retainers.
A yes, these recommendations have kept my car in pieces for years !
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
#38 |
Liked 68 Times in 26 Posts
hi, I noticed mention concerning rings earlier, also the" trick of the week camshaft" . seen lots of those, lol
#39 |
Best advice always came from grumpy old grey haired guys
Wait - what- you have to have hair? Give up Rusty just finish bolting it together and go! hahaha |
#40 |
Liked 806 Times in 246 Posts
This is somewhat of a variation on your question but over the years I've learned a lot about what you can get away with by looking at various things on race cars that have been in my shop that I never thought would have worked, usually things that I thought were way too flimsy to survive. An example was an 8 second full bodied car that had 1310 ujoints, a 3" alum driveshafts and a 10 bolt Chevy rearend, all with a ton of runs and no significant breakage. I think what happens in a lot of cases is a bracket car that progressively gets faster and lightweight parts don't get upgraded. Nice to learn lessons from someone elses torture testing.
That being said, I have a boatload of 'good idea' parts in the corner that didn't pan out. As most class racers have exhausted the easy performance improvement ideas, it comes down to a certain amount of educated trial and error. Someone once told me that at this point, if you get $1 worth of performance for every $3 spent, you're doing pretty good. Jim Caughlin SS 6019 |
