I am curious what other fox body mustang stocker racers have done to improve the rear suspension geometry/instant center? There are a few bolt-on devices that will work work within the rules, but I have also seen some guys make these cars leave hard with all of the factory control arm pickup points as well. Just curious what input or suggestions you all may have?
Thanks in advance for any isight!
Aaron Puff AWARENESS MOTORSPORTS 1985 Mustang Crate Motor Stocker |
Dick Miller has a pretty nice set up for the Fox bodies. He has a book out that is called "Hook and Launch. And the book is on EBay or at Barnes and Noble .We use his stuff and are happy with it.
Liked 79 Times in 11 Posts
global west lower arms, adjustable uppers, spherical bearings and a set of battle box reinforcements worked good on mine. 1.60-1.63 60 fts.
bob beals 7244 |
Liked 19 Times in 12 Posts
Team Z Motorsports!!! One stop shopping.
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
Liked 50 Times in 23 Posts
Team Z .. and..... Check out Baseline Suspensions, lots of info and charts on the site, Kevin will help you out...
http://www.baselinesuspensions.com/index.htm
Steve Stickel 1161 Stk 1167 SS |
Be careful of spherical rod ends when using the stock the stock mounting points on the Fox body. They tend to have side to side movement when using rod ends on the four bars. Miller has a bolt on cure for this. Again, it worked well for us.
Thanks for all of the feedback guys! I have a lot of experience with the fox stuff in street/strip trim, but not with the options that will fit the Stock Eliminator rules. I know the Team Z and the Baseline pieces are pretty similar. Any opinions or things to consider either way between those two?
Liked 275 Times in 76 Posts
Regardless of what you do, the rear upper and lower control arm mounts are weak. When you start getting the car to hook, those two points can ruin a car if damaged. Make sure they are reinforced.
Sean
Liked 24 Times in 8 Posts
This is how my friend did his upper control arm mounts. You can see where one of his roll bar tubes comes into the mount as well. Very sturdy.
