Old 09-30-2014, 03:39 PM   #1
Chris Hardy
Liked 4 Times in 1 Post
Default Is there a low volume BBC oil pump available?
Is there a low volume BBC oil pump available similar to those available for the SBC engines?
Thanks,
Chris Hardy
3038
J/SA
Chris Hardy is offline   Reply With Quote
Old 09-30-2014, 04:41 PM   #2
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: Is there a low volume BBC oil pump available?
Yes Larry Steward in Clinton Miss 601 259 1597
Old 09-30-2014, 04:51 PM   #3
SSDiv6
Schumann's Racing Oil pumps.
I believe Alan Roehrich uses Schumann pumps on his BBC builds.
http://www.schumannsdynamicperforman...ock-chevy.html
Old 09-30-2014, 05:48 PM   #4
tj310
Small block pump should fit .---Trevor
Old 09-30-2014, 07:00 PM   #5
I do. I've used Schumann pumps for several years. I also use Clay Valley Racing pumps, but they do not offer a low volume big block pump.
And, as Trevor posted below, many guys run a small block pump on big block Stock Eliminator engines.
I do not use small block pumps in big blocks, but there are those who are both smarter and faster than I am.
Old 10-02-2014, 08:16 PM   #6
Chris Hardy
Thank all of you very much for all of your input. It is greatly appreciated.
