Old 08-09-2014, 12:49 PM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default S&W Anti roll bar one more time.
A while back there was a thread on here about the ARB that S&W makes for 82-02 Camaro and Firebirds. Before I spend 500 plus shipping on one. Has anyone had a problem getting through tech with one recently? I have heard that they are now legal. Can anyone confirm this? Was planning on asking this weekend at Gateway. But could not get away from work to go.
Thanks
Rob
Old 08-22-2014, 02:19 AM   #2
zracer305
Default Re: S&W Anti roll bar one more time.
Anti rollbars in stock have been acceptable for some time now.But, if you setup your rear suspension right, you shouldn't need one. Not a believer in anti-rollbars or air bags for these cars.
zracer305 is offline   Reply With Quote
Old 08-22-2014, 10:09 AM   #3
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,388 Times in 504 Posts
Thanks
Rob
As far as I know, if it's bolt in it is legal. If it requires welding it is illegal. If it is bolted to something that has been welded to the frame, then it is questionable.
'65 Mustang SS/L & L/SA
Old 08-23-2014, 08:54 PM   #4
zracer305
One of the fastest LT1 Camaros in the land runs this S&W anti-rollbar setup.
Old 08-25-2014, 08:33 PM   #5
Stock726
Liked 39 Times in 10 Posts
Does anyone in tech even look underneath cars anymore??
Stock726 is offline   Reply With Quote
Old 08-25-2014, 08:41 PM   #6
How is that upper cross bar fastened to the frame, or subframe I guess I should say?
Old 08-25-2014, 10:48 PM   #7
Doug Blackley
Doug Blackley's Avatar
On the previous thread a number of the division tech directors weighed in on this very set up. Before purchasing one for your stocker I would suggest you contact your divisions tech director for their thoughts. I will say that if set up properly nothing more than the factory installed sway bar is necessary to make these cars work
Doug Blackley 1697 STK
Old 08-27-2014, 12:13 AM   #8
zracer305
http://www.swracecars.com/Files/pdf/40-613.pdf
Old 08-27-2014, 12:31 AM   #9
zracer305
I agree Doug!!! But, let's not forget the correct shocks, springs and solidly maintaining pinion angle throughout the launch. I set these cars up like a 3-link. Shooting for zero anti-squat. I will soon be testing my new torque arm setup. If it works to my satisfaction I'll post some pictures.
Old 08-27-2014, 05:16 AM   #10
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
The '97 Firebird I raced in stock had no anti roll bar. Never needed it. Pretty much always hooked well and went straight with no chassis twist. Very hard leaving car, front end in the air every run.
Modified stock torque arm.....bolt on traction bars.
Rich Biebel
S/C 1479
Stock 147R
