Old 08-14-2014, 12:32 PM   #21
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Default Re: Update on my foxbody
Originally Posted by Slickfoot View Post
No new update ,rained out for the 4th time in two weeks. Used the time off to replace the fan with a elec. unit how much H.P. do you think that will free up.
Slickfoot
Welcome to class racing Slickfoot.
That electric fan and w.p. setup should be good for at least 5 h.p....probably closer to 10 hp.
That's .1 sec off your e.t. right there.
As Charlie ( 7423) stated above, the Tweecer allows many adjustments and is a simple plug-n-play setup.
Their site:
http://www.tweecer.com/
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 08-14-2014, 08:24 PM   #22
Pat Cook
Using those programs, can you change from mass air to speed density and is there any performance benefits? or repeatability?
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 08-22-2014, 10:12 AM   #23
Slickfoot
Liked 2 Times in 2 Posts
Got to the 1/8 track Tues. without a rainout. The car dropped about .03 and picked up 1 MPH with the elec. fan setup. Did a best time ever 8.7019 with 77.18 mph. I tryed the timming @ 15, 16, 17, btdc with out any real change. I don't have a weather station , everyone said there cars were slower. What do you think for the the next change , more gear, MSD box , adjustable fuel reg. stock elem. cam ?
Slickfoot 3955
Slickfoot is offline   Reply With Quote
Old 08-23-2014, 12:35 PM   #24
Chris1529
Liked 70 Times in 29 Posts
Do you know anyone that has a set of 26" slicks you could borrow to try? That would go a long way to show you how much a gear change would help your car.
If you spend the money for a stocker cam along with valve springs and good lifters, your RPM range is only going to go higher. Your 3:90 gear will become even more of a problem.
A fast stocker 5.0 is going to run 7000+ rpm. You need to gear the car according.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 08-27-2014, 10:34 AM   #25
Slickfoot
Smile Re: Update on my foxbody
Last nights best 8.64 with 78mph 1/8 mile, air was 2500 ft. only changes were removed the screen from T/body and took out 20 more lbs. Still can't get to the 1/4 mile track test and tune gets rained out ever week.
By the way that a good idia about the test with a 28'' tire
Slickfoot
Old 08-27-2014, 10:54 AM   #26
alejan1975
what rpm are you launching w/ that converter?
Alex Cummings
Newb
alejan1975 is offline   Reply With Quote
Old 08-27-2014, 02:04 PM   #27
Slickfoot
2500 rpm
Slickfoot
Old 08-27-2014, 09:13 PM   #28
Chris1529
Slickfoot
26" tire. 3.90 with a 28" tire is still not near enough gear.
Chris Bowman
1984 Mustang GT350
Old 08-28-2014, 12:08 AM   #29
Slickfoot
I'm thinking of going with 5.13s I know it's alot of gear for my stock motor, but that's the gear i'll end up with when I build a motor over the winter. Might be able to put a stocker cam and springs in it to get it to run to the end of the 1/4 with 5.13s for the rest of the year.
Slickfoot
Old 09-02-2014, 05:47 PM   #30
Slickfoot
Rained out again !
What MSD box and tack should I order for this build?
Slickfoot 3955
