Old 08-08-2014, 10:26 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default 327 small shaft in 350 main block - main bearings?
I "think" there is a main bearing that allows a small main 327 shaft in a large main 350 block. Do we have a part number/vendor for that main bearing set?
Larry Woodfin 471W
Old 08-08-2014, 10:37 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: 327 small shaft in 350 main block - main bearings?
larry-- you will need a Clevite MS-1110H bearing set---FED387
Old 08-08-2014, 10:56 AM   #3
Dragsinger
Thank You
Larry Woodfin 471W
Old 08-08-2014, 10:56 AM   #4
GEORGE PETERSON
Liked 11 Times in 6 Posts
Clevite has discontinued these bearings. You have to use bearing spacers. Race Engineering has them in stock.
George Peterson
D/S 4448
GEORGE PETERSON is offline   Reply With Quote
Old 08-08-2014, 12:25 PM   #5
FED 387
OK Clevite may have discontinued them but they are still available from many sources--- jegs/Summit/Speedway motors and many others--- Also look into KingBearings.com looa at their HP line and go to buy bearings--- a e catalog will pop up and you can put your dimensions in they will give you the appropriate bearing part number---they are out there just hafta look a little Good Luck--FED387
Old 08-09-2014, 02:11 PM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I got a set of MS1110H clevite about 6 months ago, thought King had them but it was rod bearing they have to use big journal rod on small journal crank
Mike Taylor 3601
