Liked 99 Times in 60 Posts
I "think" there is a main bearing that allows a small main 327 shaft in a large main 350 block. Do we have a part number/vendor for that main bearing set?
Larry Woodfin 471W |
Liked 335 Times in 182 Posts
larry-- you will need a Clevite MS-1110H bearing set---FED387
Thank You
Liked 11 Times in 6 Posts
Clevite has discontinued these bearings. You have to use bearing spacers. Race Engineering has them in stock.
George Peterson D/S 4448 |
OK Clevite may have discontinued them but they are still available from many sources--- jegs/Summit/Speedway motors and many others--- Also look into KingBearings.com looa at their HP line and go to buy bearings--- a e catalog will pop up and you can put your dimensions in they will give you the appropriate bearing part number---they are out there just hafta look a little Good Luck--FED387
Liked 313 Times in 106 Posts
I got a set of MS1110H clevite about 6 months ago, thought King had them but it was rod bearing they have to use big journal rod on small journal crank
Mike Taylor 3601 |
