Old 08-04-2014, 12:43 PM   #11
fordteacherguy
Liked 160 Times in 51 Posts
Default Re: Piston to valve clearance
I check valve drop (P/V clearance) in approximately the same range as the other posters but also set up a handy spread sheet that takes those valve drop reading readings and also contains my theoretical valve lifts at those designated points. My spreadsheet calculates P/V clearances by doing the simple adding and subtracting and giving me a total P/V clearance. I also set up some conditional values in Excel that turn the cells red if I'm below a minimum P/V threshold. I've found building a P/V spreadsheet useful because I can move the cam degree cells left or right (simulating advancing or retarding the cam) and see what the new P/V clearance should be with the cam at those various places. Using a P/V spreadsheet also allows me to check a different cam in a bare block with a crank, get the lift @ degree numbers off of that new cam, punch the numbers in to my existing motor valve drop measurement sheet and recalculate new clearances.
As always, you DO need to physically check P/V clearance that math=actual clearance but so far it has worked great for me.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 08-04-2014, 12:54 PM   #12
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Originally Posted by SS Engine Guy View Post
You got some pretty good advice there. Only thing that I will add is to make sure everything in the valve train is up to spec and closely monitored. Also check P/V clearance at least 10 degrees BTC and 10 degrees ATC at each increment and log the readings for future reference. I usually log every 2 degrees to 20 degrees both ways and furnish that with other records on an engine. Good record keeping can make maintenance much easier.
X2. Good advice. Also make sure your cam drive (belt or chain) is in good condition. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 08-04-2014, 01:55 PM   #13
Ed Wright
Ed Wright's Avatar
I only do "valve drop" measurements to verify all cylinders have the same valve seat-to-valve pocket travel. I would never just do math to check my valve-to-piston clearance. I actually measure it in 2 degree increments 20 degrees from TDC. I have found the closest point being ten degrees from TDC to almost never does apply to my stuff. I measure it with the springs I'm going to run. I have an old Mr. Gasket on-car valve spring checker that I have modified to fit my Jessel rockers, to pull them down against the pistons. I use a long 1/2" drive break over instead of the torque wrench it was meant to use for checking valve springs. Checking with weak checking springs always show less room than it will have running.
I measure it with the cam two degrees further advanced than I expect to run it, and backed up two degrees further than I would expect to run it, on a new engine. After I settle in on where I'm going to be running the cam, the next time it's apart, if I have room, I close it up to the minimum. My pistons have a clean ring like the face of my Manley valves, and a round dark spot for the dimple in the center.
I quit using modeling clay about 1970, when Carrol Caudle told me "Ed, give that crap to a kid to play with, that is what it is meant for." LOL
If somebody tells me they bought an engine, and how much clearance should it have, I'm going to tell them way safe to keep them out of trouble.
Ed Wright 4156 SS/JA
Old 08-04-2014, 03:07 PM   #14
RICK W
Thanks for all the replies
RICK W is offline   Reply With Quote
Old 08-04-2014, 07:57 PM   #15
SSDiv6
Liked 1,581 Times in 582 Posts
Talking Re: Piston to valve clearance
Ed, you never used Silly Putty?
Old 08-04-2014, 11:31 PM   #16
Ed Wright
Ed Wright's Avatar
LOL! Nope, never tried that one. You might be too young to remember all the magazines showing how to use modeling clay, then measure it with a machinist scale or veneer calipers. That is all I had to go by until I met Carroll. He was the first sharp engine builder I got to know. Taught me a lot.
Old 08-05-2014, 12:32 AM   #17
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Piston to valve clearance
Ed, does he still have his old '55 Chevy?
Jim Cimarolli is offline   Reply With Quote
Old 08-05-2014, 09:06 AM   #18
Ed Wright
Ed Wright's Avatar
Yes he does. He sold his Don Hardy Vega, still has his last (he had three) '55.
Old 08-05-2014, 09:29 AM   #19
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Thumbs up Re: Piston to valve clearance
Originally Posted by Sean Cour View Post
I like to run them till they touch, then back them off a little!
Okay I just spit my coffee on the key board
Kevin
Old 08-05-2014, 09:32 AM   #20
SSDiv6
Not that young Ed.
I also used modeling clay many moons ago, also used Plastigauge too!
