Old 08-02-2014, 09:20 PM   #1
RICK W
Default Piston to valve clearance
What is everyone running for minimum valve to piston clearance on 350 ss motors?
RICK W is offline   Reply With Quote
Old 08-03-2014, 06:10 PM   #2
terry1
Liked 24 Times in 13 Posts
Smile Re: Piston to valve clearance
Hi Rick.I was hoping to see you in Miramichi.
How's than engine coming?
Terry K
terry1 is offline   Reply With Quote
Old 08-03-2014, 07:03 PM   #3
RICK W
Default Re: Piston to valve clearance
Hi Terry
I just bought a short block a couple of weeks ago, working away at it, ordered some valves and intake gaskets. Bowtie block this time. How many cars showed up Saturday? Talk soon Rick
Old 08-03-2014, 08:23 PM   #4
Ed Wright
Ed Wright's Avatar
.100" is safe.
Ed Wright 4156 SS/JA
Old 08-03-2014, 08:28 PM   #5
JeremyDuncan
Liked 354 Times in 79 Posts
.100" is safe.
Way safe for Intake valve.
Usually .090 on Exhaust and .040 on Intake.
Bigger the camshaft diameter equals less flex and you can tighten clearances.
JeremyDuncan is offline   Reply With Quote
Old 08-03-2014, 08:42 PM   #6
Sean Cour
Sean Cour's Avatar
Liked 124 Times in 39 Posts
I like to run them till they touch, then back them off a little!
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 08-03-2014, 09:41 PM   #7
Ed Wright
Ed Wright's Avatar
What Sean said^^^^^^^^^
Mine has .036" intake & .075" exhaust right now, but I hesitate to tell somebody that becauseI don't know how sharp they are, and I don't want to hear "I bent some valves doing what you told Me!", and him having to ask that......
No valve marks on my pistons, but no carbon there either. Just clean aluminium.
Old 08-04-2014, 12:52 AM   #8
SS Engine Guy
You got some pretty good advice there. Only thing that I will add is to make sure everything in the valve train is up to spec and closely monitored. Also check P/V clearance at least 10 degrees BTC and 10 degrees ATC at each increment and log the readings for future reference. I usually log every 2 degrees to 20 degrees both ways and furnish that with other records on an engine. Good record keeping can make maintenance much easier.
SS Engine Guy is offline   Reply With Quote
Old 08-04-2014, 07:41 AM   #9
SSDiv6
Liked 1,583 Times in 582 Posts
What he said!
Old 08-04-2014, 12:41 PM   #10
terry1
Originally Posted by RICK W View Post
Hi Terry
23 cars
