#11 |
You need a charger that is set up for continuous 40 amps. the Schumacher chargers that are inexpensive won't charge continuously at 40 or 50 amps. ( the cheap ones only charge at 40 - 50 amps about 5 minutes before kickin out) I have 2 optima batteries and I use a black and decker charger that is set up to charge continuously at 40 amps and reducing as needed.The Optima battery guy told me to charge them hard. Optima has their own chargers available now and they hit the batteries pretty hard. He said don't trickle charge them give um some juice. I hope this helps. Dave.
#12 |
I have an old Montgomery Ward 12 volt battery charger that was given to me used in the early 80's and it still going strong. Gauge and charge light still work.
As far as the Chinese Made chargers, it is not the Chinese fault that the chargers made there are junk, it is the importing company in the United States fault for the poor quality. They are the ones who spec. out the parts and materials they use in the charger. The more cheap crap they can put in the charger, the cheaper they can sell it, and the more money they make because of the volumes they sell due to low cost. Believe it or not I have seen some quality stuff come out of China but, it costs as much as something made in the USA. You get what you pay for!!
Nelson Kowal Stock 345 |
#13 | |
Liked 89 Times in 28 Posts
Weird. That's exactly opposite of what I've been told. Their high buck charger only charges at 12 amps. |
#14 | |
I believe the charge rate is voltage and temperature sensitive! http://www.optimabatteries.com/en-us...care/charging/ YELLOWTOP® Type: D51 & D51R - D35 – DS46B24R - D75/25 - D34 – D34/78 - D27F These batteries are dual-purpose. They are designed for engine start and cyclic applications and for use in vehicles with large accessory loads. Recommended charging information: Alternator:
Peter Ash 6100 STK |
#15 |
Liked 747 Times in 136 Posts
Great info gents. And thank you Alan, those Rizk are exactly what I was looking for. I just ordered the p160. Looks to be a very nice piece, and made old school solid. I may also buy one of their smaller ones as well for aroung the shop.
#16 | |
#17 |
Liked 32 Times in 13 Posts
THANKS for the info Peter. This gives me an ideas to what I need to do, now just to find the right charger.
#18 |
Liked 160 Times in 51 Posts
Bought a Schumacher automatic pro series (computer controlled charging) and there was a sprinkle of rain that wetted the charger and it went nuts and has never been the same again. Buy a old school type charger with a regular rectifier and no circuit boards. I'm on charger #2 and just purchased a Schumacher Farm and Ranch model that looks like old school type construction/ no touch buttons or computed charging, just a plain ole charger. $119 Amazon http://www.amazon.com/Schumacher-SE-.../dp/B00030BFO2
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 |
