Old 05-19-2014, 09:15 PM   #1
7423
Question Who uses what ATF and why??
"Old school" claims a Ford takes type F, GM uses Dextron, Mopar uses I have no idea. Why the different types or grades? What is the difference between them? Low power 3400lbs 5.0L EFI Ford, old school C4, 2.91 lo gear, 10" convertor, 4500 flash. What should be used in that combo?? Your thoughts please.
7423 is offline   Reply With Quote
Old 05-19-2014, 09:44 PM   #2
partsbob67
Liked 79 Times in 11 Posts
Default Re: Who uses what ATF and why??
I use mercon v. it's what my trans guy said to use. tore it down last year after 3 or 4 seasons on it and everything looked good inside. I don't think he replaced anything.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 05-20-2014, 06:46 AM   #3
GTX JOHN
Liked 2,469 Times in 695 Posts
Protrans told me Type F...................I believe higher friction coefficient.
Usually cheaper too......$3.49 at my Walmart.
John Irving
741 Stock
741 Super Stock
Old 05-20-2014, 07:42 AM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,916 Times in 574 Posts
Using type F in my powerglide now but have used dexron and synthetic before. No difference in performance or reliability with any of the different types of fluid. Having the pump pressure correct is the key to longevity at least with the powerglide.
Mike Pearson 2485 SS
Old 05-20-2014, 07:59 AM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Synthetic trans fluid runs cooler. If it's type F you want, ATI sells synthetic type F.
Old 05-20-2014, 09:03 AM   #6
Lou Jeffery
We advise our customers to use ANY brand ATF that is red in a race transmission. However in normal production vehicles the type of fluid can be a big deal.
Lou Jeffery is offline   Reply With Quote
Old 05-20-2014, 09:16 AM   #7
njk53
I believe the different transmission fluids have different friction modifiers (different coefficients of friction), different anti-corrosive and anti-foaming agents among other things. The friction modifiers to a certain extent dictates how hard or soft you want the clutches in the clutch pack to grab. GM now has DEXTRON 6 but, I don't know anything about the friction modifiers. I do know that DEX 6 is not compatable with some of the older design rubber seals.
We have a Coan transmission and were told to use Ford type F in a GM
TH350.
Nelson Kowal
Stock 345
Old 05-20-2014, 11:38 AM   #8
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Who uses what ATF and why??
I've been using Amsoil SuperShift for years. It has enhanced Type F frictional properties and is synthetic as well. Synthetics hold up better against heat which is especially helpful during hot-lapping and/or being up on the converter for any length of time - footbrake, 2-step and/or trans brake. JW does my 904's and they've said wear rates on moving parts has been excellent.
LOCOMOTION Racing
Old 05-20-2014, 01:03 PM   #9
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
X2 on the Amsoil trans fluid . 4 yrs later Paul did very very little to mine on last freshen up.
2894 STK
Old 05-20-2014, 07:45 PM   #10
Tim H
Tim H's Avatar
Liked 481 Times in 158 Posts
Type F as recommended by my tranny builder. (TH 400 BB Chevy)
