Old 05-12-2014, 06:28 AM   #1
brent flynn
brent flynn's Avatar
Default Lokar Trans Dipstick...
Im gonna put a Lokar dipstick in my Trans... Do i have to have locking type , or just the regular type? Thanks...
Old 05-12-2014, 07:04 AM   #2
jmcarter
jmcarter's Avatar
Liked 3,162 Times in 967 Posts
Default Re: Lokar Trans Dipstick...
Have to have the locking type...been that way for a while now.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-12-2014, 09:07 AM   #3
Dragsinger
Liked 99 Times in 60 Posts
Brent,
I have installed this style on several applications, works great. You can find the part numbers on Lokar web site.
"NHRA approved braded locking dipstick kit" The package has everything you need, very good quality, excellent value.
Larry Woodfin 471W
Old 05-12-2014, 11:30 AM   #4
Jim Kaekel
Liked 529 Times in 107 Posts
Personally, I wouldn't buy the Lokar assembly unless I had to have it. They are harder to fill and read than the OEM dipstick. I have to use the Lokar part because a stock type dipstick assembly won't clear my trans. brace.
If you just need the locking feature, ATI sells a neat Tube Lock #973081. Just check your fluid level using your stock dipstick and put the ATI part when you're done, keeping the dipstick in the trailer.
Jim Kaekel 3836 STK
Old 05-12-2014, 01:59 PM   #5
Ed Wright
Ed Wright's Avatar
I have the Lokar dip stick on my car. The metal transmission funnel & flex tube I got from NAPA several years ago fits just fine if I pull the locking ring down like you would to unlock the dip stick. Hold it in place while filling it, then pull it back to take the end of the flex tube back out. The factory T350 dip stick tube didn't fit my car well. I mounted the flexible Lokar tube on the inner fender.
Ed Wright 4156 SS/JA
Old 05-12-2014, 02:37 PM   #6
Dragsinger
my experience is like Ed's. Lokar has two different versions, the NHRA approved is much easier to fill. The "budget" style has a smaller tube making fluid flow slower.
Larry Woodfin 471W
Old 05-12-2014, 05:51 PM   #7
brent flynn
Do you have to use the one(lokar) that requires you to remove the pan, to install? Or just one that has a locking dipstick, at the top? Or does anybody make a factory one, for Pontiac Bird('68) with 400 turbo, that fits real nice and doesnt block the middle trans bolt? thats the real reason i want to replace it...because you have to remove it to get the middle trans bolt out, and its a real PITA..hehe
Old 05-12-2014, 06:11 PM   #8
Ed Wright
Ed Wright's Avatar
My pan had to come off.
Old 05-12-2014, 06:44 PM   #9
brent flynn
i think that will be the one that i get... im tired of not being able to get to that bolt, and i need it , anyway... been putting it off for awhile now...
My engine is still out, trans pan is drained( because i have to remove the OEM type dipstick), so now would be a good time to install it...
Cam should be here tomorrow, pick up heads tomorrow eve, then sending cam/lifters out for coating...
Old 05-12-2014, 08:16 PM   #10
R. Thorne
Liked 100 Times in 33 Posts
I drilled a hole in the firewall to access the bellhousing bolt on my car (74 gto), then plug it when not in use. When I put the turbo 200 in the car I had to use the Lokar dipstick for clearance reasons. I also mounted it on the firewall away from that bellhousing bolt. I would much prefer the stock type dipsticks. The problem with cable type dipsticks (Lokar, etc.) is they bend and flex going around tight corners and that can throw off your readings as much as a quart. Ron.
R. Thorne is offline   Reply With Quote
