I'm looking for improvements in the 60' and I'm told this is the place to ask. I'm sick of the f-body specific forums so here goes-
Car is a '90 Firebird, a bracket car. Small block, TH400, 3.73, 3500 converter, 28" tall MT radial tire. Runs 10.80-10.90's at 124mph with 1.44x 60'. Suspension consists of 90/10's in the front with Moroso trick springs, 50/50 in the rear with V6 springs, Spohn torque arm and tubular LCA's. The 60' can be inconsistent at times and I'm looking for ways to improve. I've been considering switching to adjustable shocks or coilovers but need to learn more before I do. Can any of you help point me in the right direction? This may not be the best, but it's an iPhone video my wife took last weekend. |
Liked 13 Times in 11 Posts
Yeah , this COULD be the place.........if you can get enough Stock or Super Stockers to participate..........but only a few do?
![]() Anyway , I have the same sort of post below. Good luck |
#3 | |
Liked 184 Times in 113 Posts
Consider adding weight to the back, no cost. The Torque Converter does not need a hard STR like a Stocker. If you have an computer electronic system. Retard the Launch Timing to soften the hit. Get rid of the Radial Tire. Back to the standard Slick. Radials are a cause of inconsistency. They work when they work usually with well prepared tracks. They are not at all forgiving when the track prep is not spot on. D |
I have never had a bias tire hook as well as a radial on any track. I've heard thAt repeated, but it has not been my, or any of the guys I race with's experience. I was away from this for a while when I went dirt circle track racing for about ten years. Our local track prep is a bit hit. & miss (more miss than hit)
I started out running bias tires because that is what I knew when I quit to go roundly-round. Pete Peery put me onto the radials. I ordered another set of wheels, and some same brand, same size radials. Easy 2/10 quicker in A-B-A testing, and the bias tires were hooking just fine that night. Tested that a couple more times when the track prep was not so good. I have never found conditions my radials failed to hook at least as well, or better on slick tracks. They have been at least as consistent also. As far as I can see, only most stick cars like bias tires better. Of course, they don't want stick cars dead hooking. Even Pro Stock cars like to turn them over a revolution or so on launch. Things I would look at are: Softer rear springs (just enough spring to hold the car up with coils) soft front springs (I would use no more than 275lb front springs on a Camaro. Also taller rear tires make more difference than wider. Loosen up the front end. If you knock your ball joints loose, then raise a control arm (not connected to the spindle) and it doesn't drop on it's own, it's too tight. How to do some of this would take up too much room here. PM me if you don't know how to do some of this. Hope this helped.
Ed Wright 4156 SS/JA |
Thanks for the replies.
Ed, would you recommend going to coilovers on the front? I believe that will allow for more spring options. It's hard to tell because of the video's quality, but it looks like the front end comes up briefly, sets down a bit before coming back up. Almost looks like a 'bounce' Could this be causing a problem? How does the LCA angle affect performance? I do have LCA brackets which will change the IC. |
Liked 284 Times in 87 Posts
Tony… What engine displacement, cam, intake, head and carburetor? Does the TH400 have stock rotating internals? What determined your choice on 3.73's. MB.
#7 | |
Liked 759 Times in 379 Posts
3rd gen f body bracket cars weighing 3100-3200 lbs. with driver run easy mid to low 10's with nothing special small blocks, power glides, 8" converters, 4.56 gear and 10" tires Last edited by 1320racer; 04-30-2014 at 09:35 PM. |
You might ask some fast Stocker guys. I never put those things on my car. I think they are just wrong. I see kids using those on ls1toke.com.
When I was bracket racing my car on 9" tires, I could hardly keep it off the back bumper on a good track. Ran mid-high nines that way. Usually 1.30-1.32 in 60'. I used PeteZ bars then. Had too much tire-body separation, but I lived with it until I bit the bullet and had Eastexas Racecars work their magic. I have had QA1 front shocks, could not get them ajusted stiff enough either direction. Never stopped bouncing on landings. Then went to AFCO fronts, still not enough adjustment either way. Finally bought a set of Santuff shocks. Some of the best money I ever spent. I can make it stand straight up, or barely carry them off the ground by just adjusting the front shocks. No more bouncing on landings either.
Liked 228 Times in 70 Posts
I would say more gear (4.33) and convertor(around 5000 stall). A good set of front struts from fastshocks.com. Definitely stick with the radial (go with 29x9 30x9 on 10" wheel or 30x10.5 on 12 inch wheel). I always find radial more consistent. S and w has a nice anti roll bar setup. On my firebird, I have stock rear suspension single adjustable shocks s and w torque arm and frame connectors and anti roll bar. I have been 1.21 60ft going mid 9s with 30x9 Goodyear tires. Remove weight off front and run with 100-150 lbs in trunk.
#10 | |
