Old 04-21-2014, 05:55 PM   #1
John Lang
Liked 6 Times in 2 Posts
Default 401cid Ford w/tri-power
Any Ford people out here that have knowledge of Ford factory tri-carb set ups ? I just had a guy drop off a 3-2bbl setup (Holley's) manifold and carbs for me to setup linkage, and freshen up the carbs ! Did these carbs come from the factory with accelerator pump's on all three carbs, unlike a Mopar setup ? This setup is off of 61 or 62 401 he said, and I was also wondering if anyone had the correct factory numbers that these are supposed to be? Also are they supposed to be facing the rear like the 2/4bbl's? Any help is appreciated !...... John
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 04-21-2014, 07:46 PM   #2
Rory McNeil
Default Re: 401cid Ford w/tri-power
It sounds like it is from a 390 FE, which carried a 401 HP rating. Yes, the carbs do sit backwwards, and all 3 carbs did use accelerator pumps. The carb linkage was all mechanical. I can try to find the carb list #s later, but similar setupw were also used on M code Thunderbirds, as well as 62-3 406s.
NHRA 6390 STK
M/S 85 Mustang
Old 04-21-2014, 08:08 PM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 555 Times in 216 Posts
What year was the 406 engine in....? A high school buddy had a 1960 Ford with the big engine and 3-2's.....4 speed. I thought it was a 406.
Rich Biebel
S/C 1479
Stock 147R
Old 04-21-2014, 08:26 PM   #4
rawhide
Liked 7 Times in 5 Posts
the 406 came out in 62 and was replaced by the 427 during 63. single four was rated at 385 hp and the tripower was 405. the most powerful 1960 engine was a 352 rated at 360 and had a single four barrell
rawhide is offline   Reply With Quote
Old 04-21-2014, 08:27 PM   #5
Chuck Norton
Liked 89 Times in 19 Posts
The 406 appeared in both '62 and '63, bookended by the 390/ 401 hp motor at the beginning of '62 and the 427/425 hp combination in late '63. I had a '62 Galaxie XL 406/405. Looked and sounded nasty but it had its hands full with both the '62, 409/409 Chevy and the '62 413" Mopars. The car was a little too heavy to be a serious player.
Chuck Norton
Chuck Norton is offline   Reply With Quote
Old 04-21-2014, 11:56 PM   #6
Rory McNeil
Also the first year that Ford offered a 4 speed was 1962. A 1960 would have a 3 speed on the column, with an overdrive optional.
NHRA 6390 STK
M/S 85 Mustang
Old 04-22-2014, 12:14 AM   #7
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Back in 72 I bought a 60 Galaxy 500 390 4spd for parts, I wanted the Crager SS wheels off of it, I paid 20 dollars for the car delivered and sold it for 100 or junked it, {can't remember for sure, too many years and cars ago}, I always assumed it was a factory 4 spd car, who knew.
Old 04-22-2014, 07:28 AM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
1961 Ford 390/401 carbs: Center: pn C1AE-AV, Holley# R-2436A
Front and rear: pn C1AE-AU, Holley# R-2437A
Old 04-22-2014, 12:17 PM   #9
Rory McNeil
Had to have been swapped, if it was a 1960. The 390 came out in 61, and the 4 speed in 62 (BW T10, Ford Toploader came out partway thru 64 production.)
NHRA 6390 STK
M/S 85 Mustang
Old 04-22-2014, 01:37 PM   #10
RJ Sledge
Liked 294 Times in 93 Posts
4 speed was an "over the parts counter" deal in `1961 along with the complete 3 duce setup. I believe that you could get the 390/401 from the factory but only with a 3 speed or a O/D unit. They were all column shift. The 4 speed T-10 BW trans set up was complete with shifter and boot and install instructions. All was NHRA Legal for Stock.
4 speed option from factory was only from 1962 on with Top Loader coming out in late 1963. I worked in the parts department of Hemphill-McCombs Ford taking care of warranty claims in 1964 and they were a ton of broken T10 imputs and cluster gears that were "1863'd" back to Ford. We had to keep them for Ford Rep to look at them. We had quite a collection of busted parts. Most were just thrown away after a month whether the Ford Rep looked or not.
RJ
RJ
RJ Sledge is offline   Reply With Quote
