Old 04-21-2014, 07:45 AM   #1
Pistol Pete
Pistol Pete's Avatar
Liked 816 Times in 215 Posts
Default Roller Rockers
On a Stock elim. car, are Aluminum Roller
Rockers Allowed if your motor came with
a Hydrualic Roller Cam ??
"Pistol" Pete Dutko
Old 04-21-2014, 08:21 AM   #2
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: Roller Rockers
As long as the factory mounting style (stud or shaft) remains the same, the roller-rockers should be OK. I noticed that T&D is now offering a stud mounted roller specifically designed for Stock Eliminator combinations.
Lew Silverman #2070
"The Wagon Master" N/SA
Old 04-21-2014, 09:07 AM   #3
Signman
Liked 269 Times in 99 Posts
You can run any stud mounted roller rocker.
Check geometry and lift at the valve as it may change.
