Liked 89 Times in 28 Posts
Wet with fuel, dry on the other bank. Idles fine just making no heat on the one side.
Stocker with dual plane manifold. Any ideas? Last edited by Jody Lang; 03-27-2014 at 04:37 PM. |
This is just being ran in the shop, not after making a pass.
Chev 305 Q Jet |
Liked 239 Times in 114 Posts
Wet from oil or gas ?
Liked 132 Times in 27 Posts
I had a bad MSD 7AL2 that caused something similar. I tried 2 carbs, plugs, a set of wires before I stumbled on to it.
Fuel.
This is a buddies car so I might not have all the correct answers. Thanks |
I've had something plug up the idle circuit and do something like that on a small block ford.
2009 V/SA Record Holder |
Liked 5,120 Times in 1,951 Posts
Shouldn't affect just one head with a dual plane intake.
What kind of distributor does it have in it?
Liked 8 Times in 7 Posts
sounds like the intake gasket is leaking to me...
without losers,winning means nothing. |
Not too much else that could cause this.
Ignition would have to drop every third, then every second cylinder, etc, consistently.
