Old 03-17-2014, 03:55 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Enclosed or Open Trailer
How much more does a Enclosed Trailer weigh over a Open Trailer.
Some of the Aluminum Open Trailers are about 1300 lbs.
What is the lightest of the Enclosed.?
What size vehicle would be needed for an Enclosed..?
D
Old 03-17-2014, 09:03 PM   #2
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Default Re: Enclosed or Open Trailer
Dan, the length of the trailer will be an important aspect of your comparison. You don't mention the dimensions of the 1300 lb example in your post. My rough guestimate would be 2 1/2 to 3 times heavier.
You could safely tow a 20-22ft enclosed unit with a 1/2 ton truck or SUV. Anything longer than that, no matter the construction, and I would advise you to upgrade to a 3/4 ton.
I can't give you any input on the comparative weights of trailers from competing manufacturers...sorry.
Dave Turner
SS/GT #1153
Old 03-17-2014, 11:05 PM   #3
Dan Fahey
Dan Fahey's Avatar
Thanks Dave;
That is good information.
The Aluminum Trailers were Featherlight and ACA 17.5 and 18 ft long.
My problem is storage of the Trailer.
Live in Germantown Md.
D
Old 03-18-2014, 12:33 PM   #4
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Dan - I tow an open all steel trailer with a 2004 Silverado SB 1500. It has the 5.3 engine and 3.73 gears w/automatic. I have no idea of the trailer weight, but it has to be way heavier than a aluminum version. Trailer has brakes and the truck does very well, but I don't tow over 65mph. A recent addition of Helwig air bags made it much better to tow with...no more scissor action after road dips. I like to keep an eye on intervals due to what I feel is marginal braking with this set-up.
Rich Taylor
I/SA - 321
Old 03-18-2014, 02:52 PM   #5
Doug Domm
Liked 84 Times in 21 Posts
Might be an optical illusion but I'd say your tongue height is way too high! Level out that trailer and you will see yet another improvement.
Doug Domm is online now   Reply With Quote
Old 03-18-2014, 03:51 PM   #6
HandOverFist
It sat level before the addition of the airbags...still handles really well. I will drop the ball a couple of inches next outing and see what it looks like. The bedliner coating is holding up well so far.
Rich Taylor
I/SA - 321
Old 03-18-2014, 04:11 PM   #7
Dan Fahey
Dan Fahey's Avatar
This is a good idea. I like the Pickup Truck. My car with trailer will approach 6500lbs. 5700# at current estimation with a 1300# trailer.
Have a 1994 Caprice Wagon that I have been customizing and fixing up for a few years. It has airbags, Belstein Shocks, rebuilt the ABS and Brake systems at a good cost. New Trans lots of stuff. Have a new engine being built. The current engine has 212k miles but does not burn any oil. Use to leak but got all that fixed.
D
Old 03-19-2014, 11:50 AM   #8
Run to Rund
Liked 54 Times in 27 Posts
My 21' Target open weighs 1370 lb. I can send you a pdf of the Wells Cargo brochure showing their lightest enclosed with 18' box is 2900 lb.
Old 03-19-2014, 09:09 PM   #9
Dan Fahey
Dan Fahey's Avatar
Wow nice trailer though.
What bed liner did you use?
D
Old 03-20-2014, 12:56 AM   #10
HandOverFist
D
Rustoleum from AutoZone...$59 a gallon and I sprayed 2-1/2 gallons total on the entire trailer.
Rich Taylor
I/SA - 321
