Old 02-01-2014, 08:05 PM   #1
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
Default Crank Triger Wire
To the wire guys,
how would you route the crank trigger wire, over the top of the engine under the intake to the crank, or on the inner fender to the crank???? Would there be an advantage fender over engine???
Comments would be appreciated.
Thanks,
Bob Lasko
Old 02-01-2014, 08:21 PM   #2
tj310
Default Re: Crank Triger Wire
I found it easiest along the fender , out of the way , more room through the firewall had to extend the wire about 4 ' to box in the backseat---Trevor
Old 02-01-2014, 11:59 PM   #3
JimL
Make sure you keep it away from water pump or alternator wires.
JimL is offline   Reply With Quote
Old 02-02-2014, 09:58 AM   #4
Bob Lasko
Bob Lasko's Avatar
running it along side a cooling fan wire ok?? I can run it on the fender were this wire is.
Old 02-02-2014, 11:20 AM   #5
Tom Meyer
Liked 354 Times in 120 Posts
Was told not to run the wire along side of anything that was hooked to electric motor unless it was shielded. Tom
Tom Meyer 5240 SS Stock ???
Old 02-02-2014, 12:00 PM   #6
Bob Lasko
Bob Lasko's Avatar
If using a shield ground msd wire, can it be run along the same wire as the cooling fan?????????
Bob Lasko
Old 02-02-2014, 12:48 PM   #7
Liked 1,952 Times in 439 Posts
Bob Lasko
I would not. Why ask for ignition trouble? It can be one of the hardest things to track down and deal with. The crank trigger wire is extremely sensitive to EMI and other electrical influences. It really needs to be run all by itself and carefully shielded completely.
Old 02-02-2014, 02:24 PM   #8
art leong
Also only ground one end of the shielding. If you ground both ends you will make it a EMI antenna.
Art Leong 2095 SS
Old 02-02-2014, 03:45 PM   #9
Lee Valentine
Liked 319 Times in 68 Posts
Bob, run the crank trigger separate from all other wires you'll be much happier for it.
Lee Valentine 1661 STK
Old 02-02-2014, 06:21 PM   #10
HP HUNTER
Liked 373 Times in 129 Posts
To the wire guys,
Thanks,
Bob Lasko
I use the MSD shielded ground wire, a keep it as far away from other wires.
I also ground the heads to the block.
