Old 01-08-2014, 09:13 PM   #1
CamCam
Liked 2 Times in 2 Posts
Default steel heads vs aluminum
I would like to know the pro's and con's of using the steel 291 casting head for the 396/375 as opposed to using the replacement head from Chevy? this would be for a stock eliminator engine. thanks.
CamCam is offline   Reply With Quote
Old 01-08-2014, 09:19 PM   #2
B Parker
Liked 2,343 Times in 465 Posts
Default Re: steel heads vs aluminum
More important then the head is the combo and the HP ratings. Is it a stick car and what body style Barry
Old 01-08-2014, 10:45 PM   #3
CamCam
it's a 67 Camaro and it will be a stick.
Old 01-09-2014, 12:28 AM   #4
Iron heads.
Old 01-09-2014, 09:21 AM   #5
B Parker
With that combo Alan is dead on. Now the 2 million dollar question. Who are you going to let build it? As far as I'm concerned there are only a small handful I would even think about letting do that combo. Done right the car will fly with only a 385 hp rating. Your building an expensive combo. Remember even working on a budget it's cheaper to do it right once. If you cheap out and the car doesn't run the way you would like to. You will just spend more money the second time. Barry
Old 01-09-2014, 09:47 AM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 313 Times in 106 Posts
Good advice,B Parker, Once right is cost less than,2-3 wrong.
Mike Taylor 3601
Old 01-09-2014, 11:20 PM   #7
CamCam
the short block is already done. I've been told the replacement heads are far better, I'm not looking at doing anything trick with the heads just wanted to know if the new heads are a better foundation to start with. so what should I expect by using the steel heads is there more to do to the steel heads to get them to perform. I'm a newbie so any help would be great.
Old 01-10-2014, 02:38 AM   #8
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
The DeFranks may have a brand new never run set of those replacement steel heads for sale. Contact jimmy d on here or call jim at california car cover
Old 01-10-2014, 07:35 AM   #9
You need Jimy Bridges, call 615-228-3516, and tell him I sent you.
Old 01-10-2014, 11:49 AM   #10
t.tosto
Liked 62 Times in 23 Posts
If you decide on Alum., have set of GM 401,s done by Mike Heintz for sale. If interested call 314 660 5684, have about 75 passes total.
t.tosto is offline   Reply With Quote
