Old 11-02-2013, 11:55 AM   #11
james schaechter
Liked 1,443 Times in 302 Posts
Thumbs down Re: Jeff Lee DQ'ed
Originally Posted by 1320racer View Post
maybe if you spent less time on this forum telling us how smart you think you are and more time fixing your junk, you wouldn't have delayed every racer 3 times nor been DQ'd!
All opinions aside about Jeff, kicking a guy when he is down, is in poor taste.
Maybe you should try racing a stick stocker sometime.
I am sure you would figure it out in a couple passes.
I could use some of your sage advice....
James Schaechter 3163 STK
Old 11-02-2013, 12:00 PM   #12
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: Jeff Lee DQ'ed
Sage brush or bush. Jeff glad to see you up and running at last, don't pay no mind to the nobodys. They seem to know it all............NOT
Bob Pagano A/SA
Old 11-02-2013, 12:08 PM   #13
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
this know nothing dumb bracket racer whose junk is far faster and quicker no mind a far nicer ride than that used up bucket of bolts, wouldn't put his car on the starting once no mind 3 times knowing it wasn't 100% right nor safe for me and my competitors!!
Again, less time on the net and more time fixing your junk!
FYI, jeff has a comment for nearly everyone of my posts, he's had it coming!
Old 11-02-2013, 12:13 PM   #14
dennis dunlap
As far as Mr. 1320 goes it sounds to me like The pot calling the kettle black drama ............. Jeff has worked hard and long on his car and laid out some pretty darn good numbers for first time out ,,,
dennis dunlap is offline   Reply With Quote
Old 11-02-2013, 12:14 PM   #15
1320racer
1320racer's Avatar
you are obviously easily impressed.
Old 11-02-2013, 01:16 PM   #16
Joe Toller
Liked 9 Times in 9 Posts
Did I SERIOUSLY just see YOU write that? Are you retarded?
x2, get this joker outta here...
Old 11-02-2013, 01:22 PM   #17
Mike Gray
Mike Gray's Avatar
Liked 711 Times in 205 Posts
20 minutes to clean up a small amount of fuel, what were they doing?
The stuff evaporates faster than that. I'll bet it looked like a bunch of Cal-Trans workers, 6 supervisors and 2 guys working.
Old 11-02-2013, 01:30 PM   #18
Carguy49
Liked 3,026 Times in 725 Posts
Originally Posted by Jeff Lee View Post
With no time to T-N-T as I would have liked ( car ran on its own for 1st time Wednesday night around 10:30), we found out the hard way there was not enough tire clearance to the left slick on the 96" 30" roll-out Hoosiers (previously always ran 91"-92" 29.5 M/T's), which I've stated elsewhere.
My 1st pass left some nuts that were in the trunk along with fuel from the fuel cell vent on the starting line along with heavy tire smoke in 4th. Bring on cleanup crew for 20 minutes. 2nd pass was same problem less the nuts & again 20 minute delay as NHRA checked the track & cleaned up the fuel.
D7 Tech director Ben told Rob Youngblood (as we were pitted together) that if I caused another delay, I'd be DQ'd. Rob told them we had the problem licked (or so we thought). Made 3rd run same problems, same delay.
So I spent the next few hours with a body grinder & tin snips only to find they meant what they said. The clearance is finally right (so I hope) and the vent was re-routed. Causing 30-45 minutes in delays is understandably frustrating and a burden on those racers following me so I certainly understand. I just wish I could have had time for a T-N-T but I wanted to make the last D7 race of the year. Sorry to those that had to endure the delays!
What a stand up guy. Jeff says all this and still he gets dinged for being a human. We have all been in rush and left things undone. I was working the starting line at Pacific Raceway many years ago (briefly), a socket fell out of a guys car near the starting line. When we had a break I took it to him. I asked him if he had lost something. His reply was "been looking for that". We had a laugh and went about our business. Humans make mistakes and most of us understand why. If Jeff could, he would probably like to restart the weekend. I say "Way to go Jeff."
Ron McDowell - Did Race
Old 11-02-2013, 02:45 PM   #19
R Lowry
Liked 2 Times in 2 Posts
When you qualify for a super stock race your posts might have some weight or
validity. Until that time why don't you stay on a bracket site where some one might care about all your grand adventures & BS
R Lowry
R Lowry is offline   Reply With Quote
Old 11-02-2013, 03:00 PM   #20
mtkawboy
Liked 54 Times in 18 Posts
I thought he knew the guy and was joking, I cant believe he's serious
mtkawboy is offline   Reply With Quote
