This is a hand held two-step controller. I went to NHRA accepted and it's not shown as accepted or prohibited. I have a call placed with NHRA. Anybody know one way or the other?
Jeff Lee 7494 D/S '70 AMX |
If it is not on the list as "accepted" NHRA does not allow it to be used.....Until you hear from them I would contact MSD because they are the ones who have to submit the item for approval and you could find out if that has been done or not......
D L Rambo STK 1300 |
General Regulation 8:2
(partial quote) May not be within the drivers reach.
Peter Ash 6100 STK |
#4 | |
I did call MSD today about this item. Their response? Call your tech department.
#5 | |
I can't really see a reason for that one.
Ed Wright 4156 SS/JA |
Liked 1,582 Times in 582 Posts
Ed, the rule has been out for a long time and being able to change the launch RPM would be great.
#7 | |
I still can't figure out realistically why seat belts in like brand new out of the box condition are only allowed a two year lifespan. Ours is apparently, not to wonder why, just to do or dq.
#8 | |
Liked 68 Times in 41 Posts
§ 13:62-4.7 Safety belts, shoulder harness and crotch belt (a) A quick release type safety belt, shoulder harness and crotch belt in good condition shall be compulsory on all ve- hicles. (b) Both ends of the safety belt, shoulder harness and crotch belt must be fastened to the frame of the vehicle. (c) All fi ttings and connections of the safety belt, shoulder harness and crotch belt shall be metal. (d) All safety belts and shoulder harnesses shall be worn properly the entire time the vehicle is being driven in a race. (e) All safety belts and shoulder harnesses shall bear the date of manufacture and shall not be used for more than two years from that date. (f) The shoulder harness shall be secured to the frame of the vehicle and come over a round bar at the driver’s shoul- der height . link to new jersey motor vehicel race track regulation http://www.njsp.org/news/pdf/072307_...egulations.pdf
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
Liked 75 Times in 29 Posts
Jeff
Here's your answer.... See page 302/320 in the downloaded version of the 2013 rulebook. It's in section 20, page 34 (General Regulations under Ignition). "The use of any programmable multi-point rev limiter and/or a rateof- acceleration rpm limiter, either by themselves (e.g., MSD 7561) or integrated into the ignition system (e.g., MSD 7531), are prohibited in NHRA competition." These are the only two I see prohibited from msd. 7751 is not mentioned in the 2013 rulebook.
Tom Sheehan SS GT/NA 1046 Last edited by thomas sheehan; 10-15-2013 at 03:17 PM. |
Spoke to Bruce Bachelder today and 7751 is legal. Pat Cvengros returned my call shortly after and confirmed also. I asked Pat why the RPM controller could not be within reach of the driver? I cited Ed Wright's example that you see everybody is spinning their tires due to a change in track conditions, so what's wrong with making an adjustment to help the situation? He didn't have the answer and said he would have to research the rationale. I said I've seen plenty of S/SS cars with a rotary adjustment dial within the drivers reach. I said "I'm sure that in the grand scheme of things this is a low priority issue" Sounded like he agreed but I'll order my 7751 tonight and make sure it's away from my stubby arms anyways.
