Old 10-09-2013, 11:14 AM   #1
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Default 12 bolt gears in a 9"?
I've seen the Strange drop out carrier, and recently noticed that MW had special spools for a 9" carrier to take a 12 bolt gear, although I couldn't currently find their listing for the offset pinion carrier needed to go with it. Would either of these be legal in a stocker?
kdanner is offline   Reply With Quote
Old 10-09-2013, 12:24 PM   #2
Jim Kaekel
Liked 536 Times in 110 Posts
Default Re: 12 bolt gears in a 9"?
I would think that would fall under "no crossbreeding of parts" reference that's in the NHRA and IHRA rule books.
Jim Kaekel 3836 STK
Old 10-09-2013, 07:04 PM   #3
kdanner
kdanner's Avatar
Jim, I do understand your logic there, but then again it really isn't any different than some of those low ratio planetaries which are often parts from a different brand trans. The only mention of crossbreeding is in the engine section. Hoping someone says they have run this stuff or can say that NHRA told them no.
Old 10-09-2013, 07:58 PM   #4
Bill Edgeworth
My thoughts are its probably not allowed based on what went down with the Mopar guys where the old cars could not run the aluminum center section.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 10-09-2013, 08:05 PM   #5
Jim Caughlin
Liked 806 Times in 246 Posts
No aluminum cases allowed in Stock regardless of what gears are attached so that kills it right there.
Jim Caughlin is online now   Reply With Quote
Old 10-09-2013, 08:55 PM   #6
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: 12 bolt gears in a 9"?
How about the guy who puts a third member together for a Drag Pack with this stuff? It's already aluminum, which eliminates it from consideration in an older car,but I always interpreted the "no crossbreeding of parts"rule to mean engine parts. Let's face it, in Stock Eliminator today, rear ends, transmissions and converters are way more exotic than ever. Also the 3 speeds in the earlier cars is a further refinement that is another departure from the OEM configuration. I bet the 12 bolt gear set would be good for something of an ET reduction in a Drag Pack.
Old 10-09-2013, 11:12 PM   #7
kdanner
kdanner's Avatar
Exactly. Same for the CJ, which is my intended usage.
Old 10-10-2013, 10:20 PM   #8
kdanner
kdanner's Avatar
Originally Posted by A56 View Post
Its really common in comp on the lighter or lower hp cars. Pinion gear height is more effecient. The problem is getting the gears, not many ratios available like the 9" so check that before you go any further. Get your gears REM finished and lightened and set them up properly without excessive bearing preload and youll be ahead of the game.
Mark Lelchook
D/ED F/SA
Yep, seen tons of them in comp cars myself and have read the opinions of some saying they are junk due to too much gear deflection which causes rapid wear and breakage. I figured in an automatic stocker since there is no big driveline shock they might just hold up fine.
I may just call Mark Williams and see if that offset pinion carrier is still available. I like it over the Strange deal for a few reasons:
1. It's very stealthy
2. Could be used with things like a through bolt carrier for more rigidity
3. If the 12 bolt gear deal doesn't work out, you still have a carrier you can just put a 9" gear into
