Old 10-07-2013, 09:19 AM   #11
Bobby Zlatkin
Bobby Zlatkin's Avatar
Default Re: 8.5 rear end for 1980 G body GM
And don't be fooled by the left hand threads on the ring gear. By the time I realized the deal there, I had them suckers so tight they were almost impossible to get loose.
Oh well. As they say "live & learn".
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 10-08-2013, 12:08 AM   #12
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
I don't know about you guys but around here 8.5 10 bolts for G body are like hens teeth. I found a mint one in a scrap pile but that was sheer luck. And the fact that it came out of a friends turbo regal to install a 9 inch ford was even better for me. Probably cheaper and way easier to just go with a Strange or Mosier 12 Bolt. Way better tooling, thicker case, thicker tubes. All around better piece. Probably wouldn't matter in a stocker but gear selection for a 12 bolt is better then a 10 Bolt as well.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 10-09-2013, 10:57 PM   #13
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: 8.5 rear end for 1980 G body GM
Seems to me that QA-1 offers adjustible upper trailing arms that have an offset for the purpose of installing an A body 12 bolt in a later G body car as a bolt-in.I bought stronger trailing arms for my '68 Chevelle wagon from them and got a catalog someplace. Their stuff is pretty nice, as well. While a 12 bolt is getting rather pricey, there is an excellent selection of gears and a small block car probably can't break it. Also I think someone makes an aftermarket bolt in 12 bolt housing now for the A body.
Old 10-10-2013, 10:05 AM   #14
Logus
12 bolt A body rear in a G body. 2 more Cos. that make the rear arms.
Probably easier in the long run, than finding a GN 10 bolt laying around.
http://www.maliburacing.com/iceman/
http://umiperformance.com/catalog/in...&cPath=8_60_68
Logus is offline   Reply With Quote
Old 10-10-2013, 11:55 AM   #15
Lyn Smith
Liked 971 Times in 195 Posts
How much wider is a 70s 12 bolt or 10 bolt A body rearend than the stock G body rearend? thanks for the info guys.
Old 10-14-2013, 09:59 AM   #16
Lyn Smith
I found a couple places that make the adapter upper control arms for the G body 12 bolt swap.Do the lower control arms bolt up ok?
