Liked 101 Times in 27 Posts
Mopar master cylinder has a 9/16 outlet at the front and a 1/2 outlet closer to the firewall.......can any of you brake Einsteins settle the arguement on which outlet goes to the rear drum and which goes to front disc ??? Thanks for any help.
NHRA AND IHRA STOCK ELIMINATOR 2772 |
Liked 28 Times in 15 Posts
My MOPAR PERFORMANCE cyl (there are at least 2 - diff bore diameters) has metric fittings. I have used both diameters and with rear drums, then with Grand Cherokee rear disks. with no discernable difference. mine has front brakes on the front port (with line lock).
#3 | |
Liked 889 Times in 239 Posts
The outlet closest to the pushrod is typicaly used for the front brakes on most drum / disc brake applications.
The front piston has slightly less volume than the rear ,but both develoup the same pressure. In race applications I've seen them plumbed both ways and work, but I always do mine as I said above.
Liked 6 Times in 4 Posts
http://www.swracecars.com/Files/Brak...g%2094-107.pdf
***Check the first NOTE. |
Liked 3 Times in 2 Posts
We recommend front cylinder to the back and back to the front brakes in the kits we send out.
As Tom says, I too have seen them both ways with equal results. FJ Oh yes, the masters come with fittings that take standard 3/16 lines. |
Liked 2 Times in 2 Posts
Front port to the rear and rear port for the front on mine.Wilwood's on the front and 10" Mopar drums on the back.Works great.
Nautilus Racing |
Liked 19 Times in 7 Posts
I have front brakes on the front port and the rear brakes on the rear port closest to the pushrod like the S&W instruction say. Is there more brake pressure on one of the ports? This might be helpful on a stocker with a 2 step to lock the rear brakes on the starting line but I guess could cause some brake bias issues as well? Seems to be working well and the car doesn't get upset when a high brake pressure is applied. Not using a Strange unit, im using a Mopar unit but I do have a Strange unit that will be put into service for the 2014 season.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
