Old 09-02-2013, 06:55 PM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Default 4gc carb
Anyone care to share the trick to make this carb work in a wheel stand.? I have tryed most every thing more fuel pressure 13# and down to 9# 5 degrees to 10. open spacers 4 hole 1 inch to 13/4 all i can get under the hood .If I tie the car down then it spins. Will do it off the ft brake or trans brake, SMALL BLK 327 250HP. 3200lbs 5.38 2.52 92 inch 10.5 raidail tHE ENGINE JUST QUITS IN THE MIDDLE OF THE Wheel stand drops like a ton bricks . So far 1 broken trans case 1 broken oil pan. 1 bent set of headers. I have limters on the ft and wheelie bars. Its not the wheel stand just that the motor quits. A small holley it goes right down the track. I have 2 carbs 1 Deno 1 Prc they both do it. Help.
Old 09-02-2013, 07:20 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: 4gc carb
Retard the timing on launch. Doing so, you might run faster with just the timing retarded and / or the front tied down. The cheapest / easiest solution that pops up in my pea brain.
Jeff Lee 7494 D/S '70 AMX
Old 09-02-2013, 07:22 PM   #3
james schaechter
Liked 1,436 Times in 299 Posts
Wedge Spacer?
James Schaechter 3163 STK
Old 09-02-2013, 09:15 PM   #4
Bob Gullett
Bob Gullett's Avatar
Liked 507 Times in 116 Posts
You have PM
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 09-02-2013, 10:02 PM   #5
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
I run a Deano 4gc with a heads up spacer. 7 psi leaving at 9000 in the air never a problem. This is the angle spacer. I was told you cant run a flat spacer with a 4gc.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 09-02-2013, 10:37 PM   #6
Jim Hanig
As I said have wedge spacer ran fuel psi where Deno told to start.I dont have hood cl for more than 13/4 inchs
Old 09-03-2013, 02:13 AM   #7
Jeff Lee
Jeff Lee's Avatar
You can angle mill the carb flange as well as running a wedge spacer.
Old 09-03-2013, 05:27 AM   #8
james schaechter
Maybe try lowering the float a bit. I tend to run the float in the 4gcsin my sticker just a bit lower than Deano has them set.
One thing that the guy from Product Engineering mentioned to me once had to do with fuel regulator mounting position. At the time, he was talking Q Jets, but his concern was a fuel regulator being mounted ahead of the carb. He said the g force of the launch could hit the needle on the launch and blow it off of the seat.
Our stocker would leave pretty high in J Stick at 7200 with no issues. Stock manifold with no wedge, just felpro base gaskets.
Name:	Cartoon Chevy II.jpg
Old 09-03-2013, 08:01 AM   #9
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Try lowering the fuel pressure even more, as low as 4 or 5 lbs. It works for Q-Jets.
I know it sounds backward, but what have you got to lose?
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 09-03-2013, 08:08 AM   #10
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
typically high float(s)
