#11 |
Liked 7 Times in 4 Posts
Used cam or not with a new lifter using a good BR fluid for a few passes will not hurt one bit and will make make you feel a little more at ease as well. Gibbs makes two different BR oils and works fine IMO.
Bob Aceves, 746 E/SA A&M motorsports |
#12 |
Guest
Posts: n/a
#13 | |
Liked 1,908 Times in 427 Posts
I can ask them about that. I'm sure they can move the oil band if needed. They can probably make them taller, too. The price is reasonable enough that the upcharge would probably be as affordable as most anything custom.
Alan Roehrich 212A G/S |
#14 |
Liked 96 Times in 23 Posts
I`m pretty sure the only difference between a Pontiac lifter and a Chevy is the placement of the oil band.It`s higher on a Pontiac lifter,you can get away with using a chevy lifter as long as the cam doesn`t have a small base circle.
Adam Strang 1018 STK |
#15 |
As Todd Hoven asked, will i need to run 130-ish on the seat? And what roughly , do these run, cost wise? They may be the way to go...do they lash, like a Schubeck? or do you preload them, a little?
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
#16 | |
Liked 172 Times in 81 Posts
Jim Mantle |
#17 |
Brent,
PM sent
Bill Edgeworth 6471 STK |
#18 |
Liked 56 Times in 27 Posts
Bill ,
PM sent.........
Dave Ribeiro 1033 STK |
#19 |
Brent, I would suggest a phone call to them and talk with them about the do and don't with their lifters he will talk with you and then you can decide what your comfort level would be with adjustment, spring psi , etc.
#20 |
Thanks Bob!
