Old 06-14-2013, 02:35 PM   #201
Joe Toller
Liked 9 Times in 9 Posts
Default Re: Under the index for under a grand!
I wanna be in the Patina Nationals! Quick, someone find a 78 Grill and 2bbl turbo setup!
Old 06-16-2013, 03:37 PM   #202
Billy Nees
I went to The Beav yesterday with 3 sets of front tires to see what I could learn from it. The wind was terrible and moving all around so 1/4 mile times and MPHs were all over and there weren't any 330s to boot!
I'm not a machine like Beardie, just a crazy old man trying to learn something so I made all of my runs "bottom bulbing". At any rate, I had 23, 27.5 and 29 inch dia. tires for my test and came to the conclusion that the RTs with the 23s were .009 quicker that the 27.5s and the 27.5s were .008 quicker than the 29s. The one thing that is throwing me for a loop with this is that the 60 ft times were quicker by .024 with the 23s than they were with the 29s with the 27.5s .005 quicker than the 29s! The car was really low in the front with the 23s and it does have an airdam so maybe that had something to do with it? The 1/8 mile times were .037 better with the 29s that with the 23s which I could see. As usual, any insight will be appreciated!
One thing that I AM going to do to this thing before I bring it out again will be to find some way to make a coil spring car react more like a leaf spring car! I'm in a very awkward place on the tree right now with it.
Billy Nees 1188 STK, SS
Old 06-23-2013, 05:49 PM   #203
Billy Nees
Well, other than slowing down the lift rate and killing some frontend travel, I didn't have any time this week to do anything. I did manage to get it to a comfortable spot on the tree where I'm at least mid to high .040s. Not good but better. I really need to find some time to address the rear suspension. I'm also getting really bored so I'm going to start throwing some parts at this thing the next time that i take it out!
Old 06-23-2013, 06:23 PM   #204
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Would air bags help with the launch? Maybe a cheap set of air shocks?
Lane Weber
Old 06-23-2013, 07:15 PM   #205
Billy Nees
Got air shocks. If I don't have the time to get creative this week I'll probably stick a set of no-hop bars on it.
Old 06-23-2013, 08:25 PM   #206
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
solid bushed upper and lower control arms?
or have you done did dat?
Old 06-24-2013, 04:28 PM   #207
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Certainly. The 60' beams are significantly higher than the rest of the incrementals, so it's pretty easy to pick them up with a spoiler or air dam. The quicker incrementals at the other clocks with the taller tire are a result of the additional rollout. You can stage a car crooked and pick up ET (with a slower R/T). Might not want to do it with a fast wheelstander, though. ;-)
When I had 23" fronts on the Volare, I had a breakout run against Eberst: showed more stripe than what I took, picked up a little ET and MPH. What's tripping on a VOLARE?!? I crawled under the car and started measuring things... sure enough, there was a suspension piece on the driver's side that was juuuuust low enough to trip the finish when I lifted, at least with those lil' donuts on the front.
With the Turismo, the 60' times can be dramatically different from track to track, depending on how high they have them set up. At the finish line, the nose will go over the beams, but even just lifting is enough to drop the nose into the beam, picking it up .03 and 3 mph. At Pittsburgh, my 1/8th mile ET's were fine, but the MPH was wacky lane to lane, showing that it was tripping the MPH start beam with the nose in one lane, but the tire in the other lane. I run a stripe taker when bracket racing it, but can't in Stock, so I drop the nose at the stripe on every single run. Wanna slow down? Keep your foot in it! ;-) Kinda like driving a rear-steer firetruck. LOL Even with the tall tire, you'd better bounce the front end hard with someone watching underneath with a tape measure to see if it might trip under hard braking. Finish line is about 5-5/8". Likewise, you should always check your opponent's car for what's tripping where.
Remember you used to tell me about Rusty Canfield's Charger running the same ET but changing 3 mph depending on whether or not you had the rear spoiler on? That's very likely what you were seeing: just a matter of whether the nose was tripping this beam vs that beam (or not).
Old 06-25-2013, 02:12 AM   #208
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Quote:Remember you used to tell me about Rusty Canfield's Charger running the same ET but changing 3 mph depending on whether or not you had the rear spoiler on?
Michael,I saw that 1st hand years ago when Junior had the car.He wanted to win class so I took it off,we also ditched the fugazy 1960's air cleaner.He picked up 3 mph,don't remember
how much ET.I think he bulbed in class.Not sure.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 06-25-2013, 09:42 AM   #209
Billy Nees
I'm not a real fan of solid suspension and body bushings and having them in this car wouldn't affect the cars reaction time the amount that I'm looking for.
Old 06-25-2013, 10:17 AM   #210
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Now that the first $1000 has been very creatively spent.
What would the next $1000 investment look like?
D
