Old 05-23-2013, 11:48 PM   #1
BRIAN SEATE
Default spray on header coating
Anyone ever used Eastwood exhaust coatings? If so, what do you think? Thanks for any feedback.
BRIAN SEATE is offline   Reply With Quote
Old 05-24-2013, 07:37 AM   #2
Shake & Bake
Liked 37 Times in 33 Posts
Default Re: spray on header coating
I too would like some info/views on this spray-on coating.
Thank's........
Shake & Bake is offline   Reply With Quote
Old 05-24-2013, 07:58 AM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
If you're refering to this...
http://www.eastwood.com/silver-hi-temp-coating.html
it's a high temp paint(1200 degree) no different than any other hi temp paint.
I've used VHT's for many years and it held up well on clean/ sandblasted headers.
Old 05-24-2013, 08:17 AM   #4
Joe Pinkston
Joe Pinkston's Avatar
I can't say how well the aerosol can method works, but I have sandblasted several sets of headers that were coated with this product either brushed on with foam brushes or sprayed on. The sprayed headers seemed to turn out with a more even finish, but the brushed ones were not bad. The key is to sandblast them as clean as possible, be sure to wipe off any spots where they will have any oil residue on them from your hands and fingers then follow the directions closely on drying time and getting them back on the engine to fire it up and cure the coating. For the money it's a good product.
Hey Dan Moore, you're #1.
RIP Mark Graham & WB Hutto
Joe Pinkston 2155 S/ST
Joe Pinkston is offline   Reply With Quote
Old 05-24-2013, 08:56 AM   #5
FED 387
Liked 333 Times in 180 Posts
Ditto---remeber to wipe them clean with DENATURED ALCOHOL or ACETONE--- it removes the oil from your skin when handling them and leaves no residue whereas mineral spirits or lacquer thinner will leave some residue on the metal and impede adhesion of the spray
Old 05-24-2013, 10:03 AM   #6
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I don't know about their spray coatings ,but , like Joe, I've used Eastwood's brush on stainless coating many times over the years ,and if the surface is blasted before painting ,It lasts for years!
Tom Goldman is online now   Reply With Quote
Old 05-24-2013, 10:14 AM   #7
jmcarter
jmcarter's Avatar
Liked 3,184 Times in 973 Posts
Well, you asked what we think...
Nitroplate. You won't regret it
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-24-2013, 03:03 PM   #8
Shake & Bake
I appreciate everyone's feedback. Thank's for the insight....
