Old 04-27-2013, 10:22 AM   #1
novassdude
Liked 136 Times in 49 Posts
Default Trend tool steel lifters
Any one using the trend tool steel lifters?
novassdude is offline   Reply With Quote
Old 04-27-2013, 12:25 PM   #2
Liked 1,909 Times in 427 Posts
Default Re: Trend tool steel lifters
I have several very satisfied customers using them. We will be using them in one of our own engines soon, as we lost most of a set of Shubecks when we broke a connecting rod.
Old 04-27-2013, 12:57 PM   #3
carl hinkson
Liked 18 Times in 10 Posts
I have used quite a few sets of them with zero problems
carl hinkson is offline   Reply With Quote
Old 04-27-2013, 05:34 PM   #4
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Dave Noll, EF/S ,?/SA 6526
Old 04-27-2013, 05:55 PM   #5
Originally Posted by Dave Noll View Post
Ok, I'm pretty sure this won't get answered but somebody might surprise me. I can't find a trend hydraulic lifter on their website. The only thing I see is a "Low movement" lifter. Is this meant to mimic a hydraulic ? For my engine I would use "LM75F-2H Late Model .875 Diameter, Oil hole in foot, low ment". But this is still a solid lifter. An e-mail to Trend about this subject went unanswered. So is this a don't ask/don't tell subject ? (my combo 351C 2bbl. 240 factored HP 72 Cougar) When I ordered my cam from comp they said I could "definitely" use tool steel lifters & they know it is for stock. What am I missing ?
Dave, you want the "low travel" lifter. I don't use the EDM oil hole, and don't suggest it. Get the cam nitrided, and micro-polished, do not run it without doing that. You'll need to use regular break in methods (low open pressure, moly assembly lube, 2500 RPM for 30 minutes, etc) just like you would with a regular lifter. For tool steel, you really need to have the cam micro-polished to a super slick finish, it is expensive, but not as expensive as losing a cam and lifters, and trashing an engine.
Old 04-28-2013, 11:30 PM   #6
Dave Noll
Dave Noll's Avatar
Old 04-29-2013, 06:42 PM   #7
junior barns
Liked 20 Times in 14 Posts
Been awhile since I raced but I seem to remember a measurement that NHRA had to determined if a lifter was hyd or not??? .15 or .18 something like that?? That is all it had to move.
junior barns is offline   Reply With Quote
Old 04-29-2013, 07:10 PM   #8
Charles Rainey
I have a question, in the Schubeck thread, you stated that you use Schubeck lifters and now on Trend you say you use Trend. Which is it that you use. Also, what engines do you have running Trend and what is running Schubeck. I would also like to hear your answer on the EDM hole. I work at a Industrial machine shop and I do a lot of close tolerance work for some of the local racers racers. I do get to see inside some of the engines but I by no means am a engine builder. just a lurker that gets to help. Geez could you run that kind of spring pressure on trend lifters. I do not see how.
charles
Charles Rainey is offline   Reply With Quote
Old 04-29-2013, 08:12 PM   #9
charles
It depends upon the application. In the case of our own personal engines, we bought several sets of Shubeck lifters before Shubeck closed, and before Trend began producing tool steel lifters. So, we use the Shubecks we own personally in our personal engines, for now, as we've run the same engines for quite a while. I have the Trend lifters in customer's engines, and I've sold several sets of Trend lifters to other engine builders who are not on the Trend program.
We have both Trend and Shubeck in big and small block Chevy as well as small block Ford engines.
With the proper setup we've run as much as 260# on the seat and 525# open on the Trend 0.842" lifter. It takes a nitrided camshaft that has been micropolished, the correct assembly lube, the correct break in oil, and the correct break in procedure. I know a couple of engine builders who run the cam in with a set of Shubecks they keep for that exact purpose, then swap to the tool steel lifters, and finish the break in.
A couple of the guys at Trend have advised us not to run the EDM hole, and we've had no failures. It is their product, I take their advice until I see the need to do otherwise.
Old 04-29-2013, 10:42 PM   #10
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Dave this could happen to your cam if one the ceramic lifters shatter.
astikhossw is offline   Reply With Quote
