Old 03-26-2013, 12:14 PM   #11
Stocker 2
Default Re: 1965 396/325 Holley Carb
Originally Posted by impstocker View Post
I just bought a 65 Impala and will be building a new stocker using the 396/325 motor from my old 68 Impala, (which was sold and restored back to its original 427/425 self) Engine specs are the same except i can use the "small" Holley. Not knowing a lot about it , it looks like a run-of-the-mill 1850 600 cfm Holley? Is there a NHRA replacement Holley I can use?
Will Lamprecht
My old Impala went 11.70 at 4100 in I/S with this motor. WEEE
If you are expecting performance like your '68 Impala, forget the small 600 Holley and go with a Q-Jet. Otherwise you are wasting time and money.
Stocker 2 is offline   Reply With Quote
Old 05-13-2013, 08:26 PM   #12
nhradave
Be careful on the cam swap, some 1965 had a journal cut in the rear bearing.
nhradave is offline   Reply With Quote
Old 05-13-2013, 08:39 PM   #13
Liked 1,827 Times in 414 Posts
Marvin sold Quick Fuel to the company that owns Holley. Marvin sits on the board of directors of all of it now.
Talk to Phil Vickhus, Zach Baker, or Scooter, they'll take care of you. All three of those guys have worked with us on our stuff. Zach is more accustomed to big inch stuff for the .90 super classes, and Top Sportsman / Pro Mod / Top Dragster, but he does work on the Stock Eliminator and Super Stock stuff.
You can also call Jimmy Bridges, Jimmy does great things with the Quick Fuel and Holley carburetors.
Old 05-13-2013, 09:11 PM   #14
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
The new Holley-style carburetor that Quickfuel received NHRA certification for will work on the 1965 325HP 396, as it is the same size as the carb on the 1966 300HP 327 @ 1.562X1.562/1.250X1.313. I had spoken to the folks at Quickfuel to find out if they had made any plans to certify a smaller version for the 275/270HP, but there doesn't seem to be a big demand for that particular unit. Oh well!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
