#11 |
I up loaded the pic of it when i found it in the barn along with 55 Tbird 57skylyner 65 falcon a corvair and a couple dodge flat nose trucks and a 64 tbird he gave me the fairlane for getting the falcon drivable for his son.
#12 |
You might consider talking to some of the guys that run these cars and get some feedback before you make up your mind about who to go to get your engine from.
#13 |
Oh I'm definetly gona do my home work on this. I'm probly gona do the chassis first then the engine. I do thank every one for there input. Thanks for posting the pics too. Awesome car!!!!
#14 |
Liked 6 Times in 2 Posts
Do tell Afret.. Who builds Calverts motors? Just wondering since they tend to work well and not have a lot of issues.
Dale Posnick |
#15 | |
Liked 5 Times in 5 Posts
Take care. Danny Durham |
#16 | |
Liked 2 Times in 2 Posts
Jim is right. If its not a post car its not a 'Bolt. If that's the case the only option you have in Stock is the 260 or 289 versions. In SS you can make it a GT car and run whatever you want to as far as the engine goes. But the only natural SS combo would be the small blocks. If you are dead set on building a FE for it, it would be a GT combo only unless its a post car. Either way you need to know what your end game is. Do you want to win class at Indy or just be able to run the index and run the eliminator. The other thing is budget. If you do have a post car and you are wanting to make it a top contender in SS/B. You should budget very close to 100K in my opinion as a ballpark number and you could cut that in half for a Stocker. Just my .02
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#17 |
Liked 5 Times in 2 Posts
Was it not Charlie Wescott power that got Ray Paquets car running so well? If so, go see CW. The other fast car has a BES motor from Mr. Bischoff if I'm not mistaken. If this is the case, I'm not sure why neither of these builders were mentioned.
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas |
#18 |
I think there is no doubt that CW has proven himself with the Hemi's. However, I don't believe Ray is running a motor from CW. I think CW is helping him with some stuff like the cam, transmission and clutch but I don't think he's built a S/SS FE motor to my knowledge. Now yes BES has proven they can build a competitive FE motor as well as Blair Patrick.
#19 |
ray is assembling his own engines as of now. he and charlie are working on stuff for new engine. the one in car at present is the engine that he was running.they did do some valve train work and some work on heads. i redid chassis and ray ran very few passes before resetting record. should be pretty fast when new engine is in and some more passes to get chassis worked out better. LIVE ACTION
#20 | |
Even a low buck slow CJ engine thrown together at home ends up costing a lot. A lot for me anyway on a military pension. ![]() Will be nice to see another T-bolt in Stock or SS. |
