Liked 43 Times in 15 Posts
In the process of painting my engine and want to know if anyone has an opinion on using Eastwoods engine paint with the hardener. .
thanks, Joe mocci |
Liked 858 Times in 234 Posts
Joe, Eastwoods stuff is pretty good.
Our Pro Street AMX engine was painted with their paint 10 years ago and still looks good. Their silver ceramic header paint is also excellent ,when the surface is properly prepped.
Liked 40 Times in 6 Posts
Joe, I have not had any luck with any of the Eastwood paints. I paint the engine every time I put it in the race car and I've tried alot of paints. The best for me is VHT. They make engine paint that works great. I've had good luck with all the VHT products. I just used there roll bar paint on the Camaro and it went on real nice. Jegs sells all there stuff.
Johnny Gray 1109 STK |
Thanks Tom and John......
X2 on the VHT paint.
Liked 1,538 Times in 575 Posts
The best engine paint I have found is the OEM Cummins Diesel engine paint.
If you have a clean block, apply it and let it cure, it will outlast anything in the market and will sustain chemicals with not adverse effect on the finish. |
Liked 6 Times in 4 Posts
Liked 100 Times in 45 Posts
Hey Mo,throw a few Viagara tabs in the paint.
Former NHRA #1945 Former IHRA #1945 T/SA |
I have used a variety of Eastwood paints in the past. So as long as you prep the surfaces well and use a good primer, you shouldn't have any issues. I have used their chassis, suspension, and aluminum paints and have had no problems.
Nelson Kowal Stock 345 |
