Old 12-29-2012, 03:42 PM   #21
rawhide
Liked 7 Times in 5 Posts
Default Re: 1968 Mercury Cougar GT-E 427/390 HP
Originally Posted by k.pascoe View Post
Odd that Ford only installed the juice cam 427 in the Cougar in '68, after it was listed as a option in many car lines at the begining of the model year.
All of the 427 GTE cars were automatic but Ford was planning on using 4 speeds and had a larger hydraulic cam designed for them but with the same horsepower rating.
Roland
rawhide is offline   Reply With Quote
Old 12-30-2012, 02:30 AM   #22
Rory McNeil
Liked 1,104 Times in 302 Posts
Yeah, I have seen factory sales information that claimed that the W code 427 hyd. cam engine was going to be available in the new 1968 Fairlane/Torino, and Mustang, but it seems none were ever built, at least from the factory, with the W code engine code in the VIN, and with any proof, ie paperwork.
NHRA 6390 STK
M/S 85 Mustang
Old 12-30-2012, 10:51 AM   #23
Paul Ceasrine
Liked 10 Times in 10 Posts
It is apparent that Mercury was attempting to make this car, an 'Executive Performance Sports Car',,,
Recommended for street-driven applications only, with the Automatic Transmission and Hydraulic cammed
427-E engine, Super Competition Handling Package, 3.50 Gears, FR70 X14 tires Radials (5.5" wide),
Power-steering, Power-assisted Front-disc brakes, and loaded with sound deadening material.
The 'distinctive' twin-dual chrome exhaust tips (18" length) under the rear valance.
Old 12-30-2012, 11:49 AM   #24
Paul Ceasrine
The 1968 427-E engine did feature the 'famous' 428 Police Interceptor
Aluminum dual-plane intake.
Old 12-30-2012, 03:20 PM   #25
Paul Ceasrine
K-Code,
In 1968, the 68' Mercury Cougar GT-E 427/390 HP car was not a
'desired' combination for C/SA.
The 68' Mustang 428/335 HP Cobra-Jet, and the 67' Ford Galaxie 500
427/410 HP were better combinations for the (9.00 - 9.49 Wt/Hp)
NHRA Class in 1968.
The 1968 NHRA C/SA Class Record was around 12.55
Old 12-30-2012, 07:52 PM   #26
Lee Jordan (3223) A/S
Lee Jordan (3223) A/S's Avatar
Liked 55 Times in 17 Posts
I had an old friend who bought one of these new. He almost never drove it. He was one of those guys who just liked to have things and not really do anything but look and shine. He sold it not knowing how rare it was.
He also owned Bob Gliddens Super Stock Mustang. 1968 fastback. He let my dad drive it ever so often so he could see the car run. lol
1967 Fairlane A/Stick - 1994 Mustang GT. 1989 Oldsmobile, R/SA - 2016 Z06 Weekend Street Car.
Lee Jordan (3223) A/S is offline   Reply With Quote
Old 12-31-2012, 10:26 AM   #27
Paul Ceasrine
Performance Results for the 1968 Cougar GT--E 427/390 HP
C-6 Automatic with 3.50 Gears and FR70 x 14" Tires.
In stock trim, 15.10 @ 93 MPH
Too heavy at #3616 lbs. for the Drag Strip.
Designed for a smooth road ride (road sports car type performance) with
the 'Special Competition Handling Package' and 123 lbs. of added
'Sound Deadener'.
And, 'Standard Exhaust Manifolds', not the 'special' 427 header-type
cast iron free-breathing units. A restrictive exhaust system, strangled
the exhaust flow.
The 'first' performance suggestion, install a set of 3.91 Traction-Lock
gears (at a minimum), which could get you to 14.75's @ 96 MPH.
Old 12-31-2012, 11:05 AM   #28
k.pascoe
Here is a 428 cj powered GT-E.
k.pascoe is offline   Reply With Quote
Old 12-31-2012, 11:42 AM   #29
Paul Ceasrine
More 'Show' than 'Go'.............with the 427/390 HP
Simulated hood scoop (non-functional) design.
* Engines equipped with 'Thermoactor' fresh-air smog pump
* But the exhaust system was equipped with the 'H-Pipe', to help balance the exhaust flow.
A very 'pricey car' for 1968 at $5131
Old 01-01-2013, 12:18 PM   #30
Paul Ceasrine
Power assisted front disc-brakes
Power steering
Thermoactor fresh-air 'smog pump'
Some nose lightening units that could be removed before racing at the strip.
Some nice features,
* Power-booster engine fan (Thermal-clutch)
* Police Interceptor Aluminum dual-plane intake manifold (low-riser)
* Holley Model #4150 List #4008 - 600 CFM Carburetor (1 11/16" x 1 11/16" square bore)
* Open element air-cleaner
