Old 11-22-2012, 09:47 AM   #11
70Dart499
70Dart499's Avatar
Default Re: Wanting to get into Stock Eliminator...
Double post, sorry
1970 Dodge Dart- 499" Stroker-IHRA No Box 3X40
70Dart499 is offline   Reply With Quote
Old 11-22-2012, 09:52 AM   #12
Bill Grubbs
Liked 573 Times in 67 Posts
I see you are in the Winter Strawberry Capitol of the World. Kevin and Scott Helms' mother, Pat Comstock, is a realtor in PC. Also, Brenda and I live in PC. However, none of us are Mopar people...well I guess Keven and Scott have gone to the "Not So Light Side" (ie. the Dark Side). Jeff really is a bad influence...
Buying a complete car is definitely the way to go. If you plan to build do the body first. Then start at the rear end and move forward, with a good engine being the last part. Pay mone for good parts the first time and you will not have to buy parts 2-3 times.
Bill Grubbs is offline   Reply With Quote
Old 11-22-2012, 01:43 PM   #13
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Look up this for sale. Mark Yacavone
79 Monza Stocker..Make offer its on page 2 of the for sales, this car could be very competitive with just a little updating. The folks who built this car knew what they were doing look in to it, forget it has to be a mopar there are many cheaper ways to race.
Bob Pagano A/SA
Old 11-22-2012, 02:28 PM   #14
70Dart499
70Dart499's Avatar
Originally Posted by A56 View Post
Depending on whats cheap to you, you can build a real fast 340 car for not much money, if you have the 340 core engine parts that is.
Mark Lelchook
F/SA D/ED
What car would be best to put the 340 in, my Dart was originally a 340 car before I bought it, but no way it could be put back to stock.
Old 11-22-2012, 05:43 PM   #15
Paul Wong
Liked 419 Times in 85 Posts
Your car can run a high compression avs 340 only. Depending on what your budget is, it is a good combo as long as your running a nine inch tire on your car still. My 68 dart GTS is one of the slower ones out there and will go 1 second under plus.
Paul Wong is offline   Reply With Quote
Old 11-23-2012, 07:05 PM   #16
Hemi Moose
Liked 12 Times in 12 Posts
Okay lets go though a small list of some of the Dodge & Plymouth models offered back then...I would like you're opinions on these models if it were you're choice to build any.
The early A-body Valiant Dart & Barracuda, (small block)
The later '67-'69 Dart & Barracuda (small block & big block)
The early B-body '62-'66 Belvedere Satellite Coronet's (small block & big block)
The '70-'76 A-body Dart Demon Duster (small block)
The early 70's B-bodies, Satellite Roadrunner GTX Charger Coronet (small block & big block)
The later '76 & up Volare Roadrunner Aspen R/T models (small block)
Old 11-23-2012, 07:21 PM   #17
KEN BUGAJ
Liked 18 Times in 7 Posts
Buying one I believe is the best deal,,,,
There are a number of fast Mopar's for Sale if that's what you want.
Just make sure you see it run and it's got a clean title !
KEN BUGAJ is offline   Reply With Quote
Old 11-25-2012, 02:44 AM   #18
Paul Wong
[QUOTE=Hemi Moose;357630]Okay lets go though a small list of some of the Dodge & Plymouth models offered back then...I would like you're opinions on these models if it were you're choice to build any.
The first half of this list has a ton of good combinarions but you need to be prepared to
spend 30k and 60k plus for some of the more exotic combos. I have spent it building them
myself and I have several in this group.
The latter half is where the bang for the buck is.
Old 11-27-2012, 02:02 AM   #19
Hemi Moose
Yes Paul, I've seen some of the cars you own that were posted in some of the other threads here that people took at the tracks...so if you had one to pick out of the bunch above, which one would you build or buy.
Old 11-27-2012, 03:33 AM   #20
Paul Wong
The 1962 plymouth 383 343 hp savoy i just finished, but there are a lot of good combos in that group. The body alone is prohibitively expensive to buy and restore before you even get to the drivetrain which makes these a less than attractive entry level stocker not to mention the new cars being more attractive to many newcomers over these old antiquated rides.
