Liked 116 Times in 27 Posts
Can I run a 2010 mustang with a 352ci rated @ 285hp in stock with a stick?
10.98 x 285hp +170# = 3299# would that put me in C/S Thanks. |
Liked 534 Times in 143 Posts
I knew I would get this all wrong!...lol. So, this combination is legal? how did you come up with F/S? Am I correct with the factor and weight?
Thanks again. |
Liked 2 Times in 2 Posts
10.98 = a 10.5# class which is F
So 285x10.5+170= 3,162.5# min. weight for F then you can move up or down one class so 285x10+170= 3,020# E min. weight 285x11+170= 3,305# G min. weight Now these are the class minimum weights without nitrous. You have to weight at least the minimum of the next class up with nitrous. So if you were running as an E car with nitrous you would have to weight F's minimum. If you are from the Bayou that rule doesn't count. ![]()
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 Last edited by 69Cobra; 11-06-2012 at 02:21 PM. |
#5 | |
http://classracer.com/classes.html |
I forgot your weight question. For F/S you would need a minimum weight of 3,160 lbs. Here's the math.
10.5 x 285 = 2,992.50 You round down to the nearest 5 lb increment, so.... 2,990 + 170 = 3,160 |
Liked 5 Times in 1 Post
Guys,
I'm new to the world of Stock and Super Stock and I'm now confused. I'm not aware of a 2010 model mustang that came with an engine even close to the 35X cubic inch range and am sitting here wondering how he can run in stock? Especially with a stock crank and stock dimension rods? did I miss something when I read the rules? Thanks, Scott Lovell |
Hey Scott,
Welcome to NHRA I know you are or were a NMRA guy for quite awhile. If you click on the NHRA Competition link in the header above and then go to stock car classification guide then go to Ford 2010, Mustang it will give you the NHRA accepted options for that year, make and model. The 352 and the 428 options for this year were paper motors that came in the 2010 Cobra Jets only. These are pushrod motors the 352 is a 302 based engine and the 428 is a 351 based engine. In the same area were you find the stock car classification guide is also the engine blueprint/spec guide. Do the same there Ford, 2010 and it will list part numbers and specs for the engine of your choice. Hope that helps.
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
Yep. Thank you Sir, that does help.
But I still feel like I'm missing something. What do you mean by "paper motor"? I'm fairly sure I was unable to buy/order a 2010 mustang with a 428 in it back in 2010. I guess I'm not understanding why that engine is legal in stock if I wasn't able to buy a car like that, special production run or not, from Ford in 2010? Thanks again for your help. Sorry for the amateur questions. Scott |
#10 | |
Liked 369 Times in 127 Posts
Confusing, yes. All Ford did was submit specs for the 352 and 428 to NHRA and they (NHRA) approved an engine combo that only existed on "paper". Hence the paper motor reference. Ford never built those engines. As posted above: 352 is a 302 block poked and stroked with Z304 Ford Racing heads and a 4 -blade throttle body. In stock there has to be the correct part numbers on the intake, t.b., heads and of course the pistons and rods have to be to spec. (among other specs listed in the engine blueprint sheet for the 2010 Ford engines) That engine is built pretty much from the Ford Racing catalog, for the most part. To the o.p.: Congrats on having a 2010 CJ Mustang. Have fun with it !
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 11-06-2012 at 06:20 PM. |
