Old 09-13-2012, 08:38 PM   #21
brent flynn
brent flynn's Avatar
Default Re: vega steering box...
Originally Posted by Todd Hoven View Post
I'm not sure you would have a problem running that box. I think if you get the bumpsteer corrected. And your car doesn't do the death shake when it hits the ground, you should have no problems. Pepole have been running them for years
Were the original Vega boxes cast iron? That would be the way to go, if you could actually find one... i think i will keep using mine, for now... switching headers, anyway....
Old 09-14-2012, 08:07 AM   #22
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Yes original vega box is cast iron they are probaly still some floating around. They are a good box
Mike Taylor 3601
Old 09-14-2012, 11:18 PM   #23
brent flynn
Mike Taylor 3601
How much hassle is it to fit one to the car? I always thought they were a direct bolt on, except pittman arm....
Old 09-15-2012, 01:15 AM   #24
They'll bolt to the frame, but the steering shaft is smaller than the std GM ones..It would need to be adapted.
Old 09-17-2012, 01:44 PM   #25
Mike Taylor 3601
The other thing I don't know about is the pitman arm when installing on rear steer car I guess it's going on firebird in picture.
My car is front steer and everything lined up except adapt spline,not sure about on rear steer car though
Mike Taylor 3601
Old 09-22-2012, 12:03 PM   #26
ken robinson
Liked 224 Times in 87 Posts
Hey Todd , my camaro doesn't get that death shake with the stock big box . But the cars that do is that a bump steer problem or is it related to other issues ?
