#21 |
Liked 308 Times in 103 Posts
Where in rule book does it say anything about has to be 2 bolt block?
Mike Taylor 3601 |
#22 | |
Liked 49 Times in 15 Posts
All the things I do to my blocks (block true, lifter true, align hone, etc), need to be done to a new Dart block as well. If you have never used one you should note that they don't come finished. The fact that Dart is not making a "small bore block" means you will need to install sleeves, just like we do in 307 & 350 blocks. The only difference is that we start with, as you put it, a $50 block instead of a $2000 block. The required prep work is the same.
Dean Feiock -- Stock 5002 |
#23 | |
Liked 72 Times in 27 Posts
You are missing my point....NHRA doesn't care if you put 4 bolt caps on a 305. They don't care if you cross bolt a 428 or 390 FE or 440 Chrysler. They don't care. Thats why they approved all the aftermarket blocks.
