Old 08-09-2012, 10:20 PM   #11
james schaechter
Liked 1,428 Times in 296 Posts
Default Re: jerico dr4 fluid
Originally Posted by Tom keedle View Post
is that redline's shockproof you guys are talking about?
i run it in my harley...
Yes. It is sticky and slippery at the same time.
James Schaechter 3163 STK
Old 08-09-2012, 11:42 PM   #12
Run to Rund
Liked 54 Times in 27 Posts
I use Torco RTF (racing trans. fluid) in all my manuals, car and truck.
Old 08-10-2012, 12:15 AM   #13
Bobby Fazio
Bobby Fazio's Avatar
I was running the red line shock proof but jerico told us to take it out and use mobil-1 75/90 instead.
'65 Mustang SS/L & L/SA
Old 08-10-2012, 02:08 AM   #14
Rory McNeil
Liked 1,100 Times in 301 Posts
I`ve also been using the Redline "light shock" in my Jerico (the blue stuff), I used to fill the trans to the fill plug, but I think I will try 1 quart next fluid change.
I also use Redlines "heavy shock" oil (the pink stuff), in my diff, as mentioned, this stuff clings like crazy! Earlier this year I pulled the diff cover after the car sat over the winter, and there was still oil clinging to the top of the case.
And speaking of Jericos, am I the only guy who has troubles with gear oil seeping out the front? Its not the input shaft seal, i`m guessing it must be from the cluster shaft area. It doesn`t drip onto the ground, but always seems to have a drop sitting at the bottom of the scattershield.Any easy fix?
NHRA 6390 STK
M/S 85 Mustang
Old 08-10-2012, 06:23 AM   #15
james schaechter
No, you aren't alone, but it might be time for a new steel bushing in the front of the case. When that gets loose, bad stuff can follow. You can order a new bushing from Jerico if the case is ok. If you know someone that can machine a bushing, you can do a custom one if the hole for the bushing is loose.
Old 08-11-2012, 12:10 AM   #16
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
They all leak. The one I have now is only a slow leak. My old one leaked so bad my son had to wipe it off in the staging lanes before the run. LOL
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 08-11-2012, 01:15 AM   #17
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Sounds like mine. I got an oversized bushng from Jerico and it's a lot better for now. They make several sizes of bushings so it's a known problem.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 08-11-2012, 06:39 AM   #18
69Cobra
Liked 2 Times in 2 Posts
I run 1 quart of Royal Purple 75/90 and so far so good. The more you change it the better but I do want to try the redline products to see if there's a difference. Also, we just put some silicon on the front countershaft area it seems to help with the slow leak issue just clean the area really good with some brake clearer and it should be good.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 08-11-2012, 12:28 PM   #19
Run to Rund
I got the HD case, top loader only, of A206 aluminum. No leaks.
