Old 06-24-2012, 10:58 AM   #1
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default jerico input shaft sensor
looking to install the input shaft sensor on a jerico trans,but the issue is i do not have any room to install the sensor between the throw out bearing and the bearing retainer ,,has anyone had this issue??? i also have the shortest throw bearing i could find gmonde
Old 06-24-2012, 12:01 PM   #2
Liked 1,775 Times in 404 Posts
Default Re: jerico input shaft sensor
Most systems don't install an input shaft sensor. They use engine RPM, and a drive shaft speed sensor. Then, using the gear ratio in the transmission for each gear, they can calculate clutch slippage. It eliminates the problems you're dealing with. You really don't want a sensor and the attending wiring in there, for several reasons.
Old 06-24-2012, 01:22 PM   #3
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Don't know where I saw this and it might have been here but someone used the fill plug hole for the pickup mount and the collar is on what looks like the countershaft inside. I saved the pictures but they are very small and of course I didn't save any details. Hopefully somebody else did.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 06-24-2012, 01:30 PM   #4
gmonde
gmonde's Avatar
can you email me the pictures,, i was thinking that i could pick up from inside the case but it would have to be 1-1 to get the correct count gmonde
Old 06-24-2012, 01:44 PM   #5
Dave Casey
Liked 769 Times in 162 Posts
Search here in the tech section and you will find it i believe, you don't need the 1:1 if your data system can apply a ratio to the graph, which some can I am told. just apply the head set ratio and put the sensor on the counter shaft. The problem is that the bellhousings in stock are not as deep as let say pro stock and they can get the sensor in there easily. Last I knew they used sensors on the input in pro stock,
Dave Casey 1330 STK
Old 06-24-2012, 02:41 PM   #6
gmonde
gmonde's Avatar
not get long winded but the amc blowsheild bellhousings used to be real deep almost 8" ,since then they changed the depth to the chevy style and the flywheel for the amc is not as narrow as a chevy so it makes for no clearance inside as it was i had to fight for throw out bearing clearance ,, i will search it here thanks gmonde
Old 06-24-2012, 03:47 PM   #7
Dinsdale
Dinsdale's Avatar
Better yet, here's the thread I stole the info from.
http://classracer.com/classforum/sho...ghlight=jerico
Dale Posnick
Old 06-24-2012, 08:23 PM   #8
gmonde
gmonde's Avatar
thanks for diggin that up it looks like thats the route i will go thanks gmonde
