Old 05-23-2012, 11:16 AM   #11
Phillip marvetz
Phillip marvetz's Avatar
Default Re: Aluminum exhaust tubes, why not?
I would think the reason people don't use it is because it's harder to bend, I have never tried to run any thru my pipe bender but I suspect it would be prone to collapsing or cracking and most exhaust shop's are not capable of doing mandrel bends.
Oh and we don't run mufflers on racecars, lol
2009 V/SA Record Holder
Old 05-23-2012, 12:29 PM   #12
Barnstorm
Barnstorm's Avatar
In the sixties we made some hedders out of a flange kit and "flex-a-tube" bendable aluminum tailpipe in about an hour on a 57 chev and picked up 3mph. No collector. Warren Johnson looked at it and wished us luck.
Old 05-23-2012, 12:53 PM   #13
Phillip marvetz
Did it sound like a Duesenburg?
Old 05-23-2012, 02:07 PM   #14
2percenter
Not meaning to shoehorn into this class again, I was confused as to what this tech forum was specific too, so forgive the rant.
I'll interject with one small note, thin gauge Aluminum tubing is readily available from any good stocked speed shop in many sizes ranging from 2" all the way up to 5" along with many sections which are already mandrel bent. Straight sections are also available of course.
I was just wondering because so many people have to run exhaust systems in other classes and with so many noise restrictions nowadays, Aluminum for the system along with the Mufflers may be attractive to some. The Turbo guys use them for many applications on their hair dryer combos. What puzzled me was; is there an exhaust flow hampering with its heat being evaporated before it reaches the end of the system?
Maybe it's a cost issue.
2percenter is offline   Reply With Quote
Old 05-24-2012, 11:15 AM   #15
James L Miller
Liked 25 Times in 16 Posts
I've wondered if the collector could be made of aluminum? It might last on a drag car.
Mopar 2 Ya!
Old 05-24-2012, 11:56 AM   #16
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Aluminum exhaust tubes, why not?
They wouldn't run quicker with full exhaust either. LOL
Mine did!
I'm always messing with jetting and after a couple of years running TTI step headers with collectors and jetting it as best as I could, I switched to a 3" exhaust with an X-pipe and ending at the rear housing with Dynomax Ultraflow mufflers. The extra 60+ lbs was removed from elsewhere in the car and it wanted jetting 1-2 numbers less. But in the end, I picked up .05-.10. I believe it was mainly the X-pipe.
If I didn't think it helped, it wouldn't have stayed on. It's cramped to swap center sections and the exhaust has to be dropped for trans swaps or disconnected for teardown.
It scared the heck out of me for a while because I heard things I never heard before!
Old 05-24-2012, 12:38 PM   #17
Ed Wright
Ed Wright's Avatar
I would have to question the headers. An H pipe between the headers might have had a similar effect, but I have a problem thinking the headers were correct. I have had some pretty long collectors in the past on my old Jr Stockers. Like 24" extensions on one PG car. Total of 36". Can't tell you how many people told me it was wrong. Wrong headers and too poor to buy more at the time. LOL
Ed Wright 4156 SS/JA
Old 05-24-2012, 03:55 PM   #18
2percenter
An Aluminum collector might not survive the heat source from the primary header tubes that's blasting only a few inches behind. The rest of the tubing doesn't see actual flame but a respectable amount of heat.
